jphelps1511 Posted September 11, 2008 Share Posted September 11, 2008 I cannot seem to fix this plotting effect. When I plot to a printer or a pdf, all of the test appears has an outline for each letter, instead of a simple solid letter. See the attached pdf called delete and look at any word in red or blue. I tried changing the colors or line weight (0.13mm) to no avail. Driving me nuts!!! Does anyone know where this effect is coming from and how to get rid of it. It's AutoCad 2002 delete.pdf Quote Link to comment Share on other sites More sharing options...
jaylo23 Posted September 11, 2008 Share Posted September 11, 2008 Is the text in model or paperspace, if in model you might either want to turn hide plot off for the viewport (if it is on) or move your text to paperspace. If text is in paperspace try unselecting "hide paperspace objects" under the plot dialogue box. Hope this helps? Quote Link to comment Share on other sites More sharing options...
BOB'27T Posted September 11, 2008 Share Posted September 11, 2008 Is TEXTFILL set to 1? Quote Link to comment Share on other sites More sharing options...
jphelps1511 Posted September 11, 2008 Author Share Posted September 11, 2008 BOB'27T, Setting the TEXTFILL to 1 solved the plotting issue. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
