Thank you Renderman.
And thanks for your encouragement, I have been learning a lot from you dear Renderman, as well as from the other experts in this GREAT FORUM.
You're welcome. :)
However, let there be no mistake... I am NO expert (yet). 8)
But what about your last example . :shock: it's really odd and advanced in all words. :lol:
That is exactly what I was going for... odd, and advanced! :P:lol:
  • Replies 38
  • Tharwat
    13
  • alanjt
    10
  • Lee Mac
    10
  • BlackBox
    5
Reference code snip:
(if (setq startPoint
          (getpoint "\n  >>  Pick the Start Point of a Line: "))
 (setq endPoint
        (getpoint "\n  >>  Now... Pick the End Point of the Same Line: ")))
Nice logic example (intension is to get the second point if the first point is picked). Here are several other ways you can replicate that intension.
(and
 (setq sp (getpoint "\nPick first point"))
 (setq ep (getpoint "\nPick second point")))
not exact, because of the use of a boolean in place of a conditional.
(cond
 ((setq sp (getpoint "\nPick first point"))
  (setq ep (getpoint "\nPick second point"))))
However, if you wanted to add to the critera "hygenic variable creation", you can use a method like:
(if (setq sp (cond ((getpoint "\nPick first point"))))
 (setq ep (cond ((getpoint "\nPick second point"))))
and so on...
Thank you Se7en for your several examples.
Your last example is really unique .
Very nice, Appreciated.
Tharwat
Hello.
Is the following codes are better than my previous one in use of single selection set which would not return nil ?
(vl-load-com)
(if (and (setq ss (entsel "\n Select Line :"))
 (setq ss (car ss))
 (setq Nme (eq (cdr (assoc 0 (entget ss)))"LINE"))
        (setq obj (vlax-ename->vla-object ss))
             (setq len (vla-get-length obj))
Thanks
Tharwat
If you want a vla-object without using the (if (ssget) (vlax-for)) combo, you might try this:
(vl-load-com)
[color=black](if (and (setq eName (car (entsel "\n Select Line :")))[/color]
[color=black]         (= "AcDbLine"[/color]
[color=black]           (vla-get-objectname[/color]
[color=black]             (setq lineObj[/color]
[color=black]                     (vlax-ename->vla-object eName)))))[/color]
[color=black](setq len (vla-get-length lineObj))[/color]
[color=black](prompt "\n  <!>  Object Selected is Not a Line  <!> "))[/color]
YES. Renderman.
Really very nice example, I like it with the "AcDbLine" .
And my previous example was indicated to Alanjt because of the use of (car (entsel ..... together and he
asked me to read the link that he uploaded to me some posts back.
So I realized or thought that he may mean not to use car with entsel at the same time.
For example, get the entsel first and get the selection later with car as I did in my example ...Maybe. Hope that he may reply.
Thanks a lot for your reply.
Tharwat
(defun foo (/ e l)
 (setvar 'errno 0)
 (while (and (not l) (/= (getvar 'errno) 52))
   (if (setq e (car (entsel "\nSelect line: ")))
     (if (eq "AcDbLine" (vla-get-objectname (setq e (vlax-ename->vla-object e))))
       (setq l (vla-get-length e))
       (setq l (prompt "\nInvalid object!"))
If I were to speculate at Alanjt's meaning...
It is perfectly acceptable to combine functions into one line of code to be succinct. One should simply try to avoid errors where possible.
Examples:
(car nil) = nil
(vla-get-layer nil) = *error*
RenderMan is correct. There's nothing wrong with combining functions, as long as they will not error if fed 'nil'.
(car (entsel)) OK
(vlax-ename->vla-object (car (entsel))) NOT OK
(entget (car (entsel))) NOT OK
Tharwat, I was referring you to the link because there were a lot of really good single selection methods posted.
Thanks Alanjt.
I did understand your point at the beginning but after reading lots of examples, I could not concentrate well at mine
and I thought that I should give it a try in another way, so that's why I changed it in post 24 with separation of ( car )
as you can see it in there :)
So according to your last information I can say that both are correct regarding to (car(entsel...)) and except the condition
status with *if* must be more accurate or used to check for availability.
Thank you so much for your efforts and your time.
Tharwat
Just to add some variation to the mix :)
(defun c:test ( / foo o ) (vl-load-com)
 (defun foo ( utils / e p )
   (vla-getEntity utils 'e 'p)
   (if (and e (eq "AcDbLine" (vlax-get e 'ObjectName))) e (foo utils))
 (if (setq o (foo (vla-get-Utility (vla-get-ActiveDocument (vlax-get-acad-object)))))
   (vla-get-length o)
   (vla-get-length o)
I hope you don't miss. :wink:
Why not? :?
Command: TEST
Select object:
Command:
Error: Automation Error. Description was not provided.
Command:
Command: TEST
Select object:
Command:
Command:
:oops: I swear that didn't do that when I tested it - how embarassing
An attempt to retain my dignity:
   (if
     (not
       (vl-catch-all-error-p
         (vl-catch-all-apply 'vla-getEntity (list utils 'e 'p))
     (if (eq "AcDbLine" (vlax-get e 'ObjectName)) e (foo utils))
   (vla-get-length o)
A minor fix. I won't tell.
