sandiegophil Posted September 9, 2010 Posted September 9, 2010 Hello, I am looking for a simple way to migrate styles from a 2010 template into a 2009 template. Any help is appreciated. Thanks, Phil Quote
lpseifert Posted September 9, 2010 Posted September 9, 2010 see here http://www.cadtutor.net/forum/showthread.php?51870-Point-Label-Style-in-Civil3D or look at 'Similar Threads' below Quote
sandiegophil Posted September 9, 2010 Author Posted September 9, 2010 Thank you for the information. However I am trying to import 2010 styles into 2009 and I can not open the 2010 file in 2009 in order to drag-and-drop the styles. Do you have any other suggestions? Thanks, Phil Quote
sinc Posted September 9, 2010 Posted September 9, 2010 Short answer is "you can't". You have to create your styles fresh in C3D 2009. There is no way to export Styles from C3D 2010 to C3D 2009. Quote
sandiegophil Posted September 10, 2010 Author Posted September 10, 2010 Richard, After several attempts from many, many angles I have found that you are 100% correct. Thanks to all for the posts! Phil Quote
