zintonio
Join files dwg in one dwg
zintonio
Many thanks for reply. You are right. I was distracted. I try the following, seems to work but obviously i have to put all the dwgs into the same foder of the new dwg. (defun c:main ( / name path prefix i nr ) (setq prefix (getvar "dwgprefix")) ; In this point i want to put a shell window that let me to choose the file to insert in. (setq i 0) (repeat 2 (setq i (1+ i)) (setq nr (cond ((> i 99) 0) ((> i 9) 1) (t 2) ) ) (setq name "A") (repeat nr (setq name (strcat name "0")) ) (setq name (strcat name (itoa i))) (setq path (strcat prefix name)) (command "_-LAYER" "_M" name "") (command "-insert" path "0,0" "1" "1" "0") ; in this point I have to: 1. explode the block; 2. select the whole exploded; 3. put it into the layer "name" (princ (strcat " " name)) ) ) Thanks a lot
Share this post
Link to post
zintonio
(setq i 0)
(repeat 2
(setq i (1+ i))
(setq nr
(cond
((> i 99) 0)
((> i 9) 1)
(t 2)
(setq name "A")
(repeat nr
Share this post
Link to post
fuccaro
If you are familiar with Lisp, try to explore the GETFILED command.
Share this post
Link to post
