error: bad argument type: point: nil
Hello All,
I am working on several programs to increment an attribute tag value and they seem to be working very well. During this process I decided to remove the looping functions that I normaly use and replace it with while. I ran into a few obstacles, But I got through it. I wanted the program to loop the insert command and when I right click the mouse it would return back to the dialog main function. Upto this point all seems to be working well except when I exit the program through the exit button, The program exits and leaves this message at the prompt:error: bad argument type: point: nil
This portion of the program is all I modified to get this error.
     (while
         (setq INPT (getpoint "\nInsertion point:"))[color=red];Get the insertion point[/color]
         (cond
           ((= INPT nil)(ECP_MF)))                       [color=red];When right click of mouse, Go to main function[/color]
         (setq IANG (getpoint INPT)                    [color=red];Get the insertion angle[/color]
               INPT (trans INPT 1 0)                     [color=red];Translate insertion point coords[/color]
               IANG (trans IANG 1 0)                     [color=red];Translate insertion angle coords[/color]
               RAD# (angle INPT IANG)                  [color=red];Get the angle in radians[/color]
               DEG# (ECP_RTD RAD#))                  [color=red];Convert radians to degrees[/color]
         (if (and (> DEG# 90.0)(<= DEG# 270.0))  [color=red];If insertion direction is > 90deg and <= to 270deg[/color]
             (setq RAD# (ECP_DTR (+ DEG# 180.0))))) [color=red];Add 180deg to DEG# and convert to radians[/color]
         (command "._-insert" BNAM$ INPT 1 1 DEG#) [color=red];Insert block[/color]
         (ECP_IAV)))))                                          [color=red]; Go to selectionset functions[/color]
 (princ))
Any clues as to what is wrong would be quite helpful. As far as I know the nil error would be from the right click of the mouse, But how to clear it is a bit confusing.
Thanks
Edited by The Buzzard
Hello Buzzard.
I hope that my guess would give a help. :)
have you added the (defun *error* ( msg ) to your Program ? It might help to obtain the sudden exit.
Wish you best of luck.
Tharwat
Hello Buzzard.
Tharwat
Thats the odd part. I have this on my exit button:
  (action_tile "cancel" "(done_dialog)(setq BUTTON nil)[color=red](ECP_RUS)[/color]")
The ECP_RUS function goes to my restore user settings function. It should clear the error although I am not sure.
But thats a good point, I should look into that since this is kind of an intentional error.
And Thanks
Its hard to say for sure without seeing a bit more code
What is the Return Value of the ECP_IAV function? As it is the last function to be evaluated in the progn statement a nil here could end the function
Another possibility could be to move the (ECP_MF) outside the while loop
(while
 (and
   (setq IANG	(getpoint INPT))
 (setq INPT (trans ...  )))
(ECP_MF)
Regards
Jammie
(while
(and
(ECP_MF)
Regards
Jammie
The point to having it where it is when INPT is nil or the right click of the mouse , I want the program to return to the dialog which is run thru ECP_MF.
The ECP_IAV function is just a selection set function after the object is inserted. If INPT returns nil and goes to ECP_MF it will never get to the selection set which is the intention. Since INPT has a nil value I believe this is whats causing the error, But I cannot clear it before the program exits. which is what I want to do.
Have you tried to change the settings of the options in Autocad to Right Click option ?
Or, you may do not give the chance to the program to exit unless to chose an options ( Exit the Program [Yes/No] : )
What you think ?
What you think ?
Right clicking the mouse is the intent to cause INPT to go nil which brings me back to the dialog where I can exit thru the exit button. All this works great. I just get the message after the program has ended.
The problem could be that you are still in the while loop after evaluating (ECP_MF)
 (cond
When ECP_MF completes, as there is no break point AutoCAD interprets ECP_MF as a sub function & will continue with the original loop
The next line
could thow an error now if INPT is nil
 (cond
The next line
Thanks for that jammie, But I already found that out while continuing to mess with it point by point. I will have to find another way. Thanks
Good looking out jammie. I got it fixed by trial and error and there was plenty of both.
The program works great. I will post it when its complete.
Thanks you and tharwat313 for the help.
Here is the section I fixed.
     (while
       (if
         (/= INPT nil)
           (setq IANG (getpoint INPT "\nGet orientation angle:")
           (ECP_IAV)
     (ECP_MF)
 (princ))
Your welcome The Buzzard, glad to be of some help. Sounds like your program is coming along nicely
Regards
jammie
Congratulations Buzzard.
I was sure that you would make it, and I am so happy for you .
Best Regards,
Tharwat
Thanks Guys,
