Hi,
I'm trying to create a selection function, that only selects items from current layer.
The problem is that after ssget i need to specify what to do with the selected items.
What I want is to simply select items like with a mouse, so i can use ACAD edit options to move, copy, delete, change attributes.
Here is the code I have so far.
(defun c:select1 (/ lay)
 (setq lay (getvar "clayer"))
 (if (ssget (list (cons 8 lay)))
   );; progn
 );; if
);;c:select1
It selects items from current layer but after I finish selecting it just writes nil because there is no action specified after progn. Can any one tell me how to add the ssget selected pool to ACAD selection? I want it to work as a simple version of qselect. It's propably a simple line of code, but I wasn't able to find it so far.
P.S. Thanks for help if any will be provided ;)
Congrats on your first post, and welcome to the forums!
I believe you're interested in the sssetfirst function, more information found in the Developer Documentation.
Also, if you'd like, you *can* combine a couple lines of code (that doesn't mean you have to), like this:
 (if (setq ss (ssget (list (cons 8 (getvar 'clayer)))))
Hope this helps!
(sssetfirst nil (ssget (list (cons 8 (getvar 'clayer)))))
(defun c:select1 ()
);;c:select1
Thats exactly what I needed.
Thanks.
