davecuster Posted September 16, 2010 Posted September 16, 2010 I have several clients a month bringing in .sldasm, .sldprt file types and I can only open 2003 to 2007 SW files in Inventor. Is there anyone willing to resave a few files for me as an older version of SW? Or any other file type I can open in Inventor or AutoCAD Thanks in advance. Quote
shift1313 Posted September 16, 2010 Posted September 16, 2010 Hey dave, are your clients not willing to export the files as iges or stl files for you? What version of SW are they running? Quote
davecuster Posted September 16, 2010 Author Posted September 16, 2010 Apparantly not....the client was basically tired of dealing with the designer and he didnt get the file types I asked him to have exported. Ive learned not to ask who was doing the design work for a client up to that point. I have an add-in for Inventor '08 that should allow me to open sld files (as long as its '03 to '07), even though they will come in a dumb solids.....but yes, iges, acis,stp....etc, would all do the trick. Quote
shift1313 Posted September 16, 2010 Posted September 16, 2010 What year SW are they using? 2010? Quote
davecuster Posted September 16, 2010 Author Posted September 16, 2010 I cannot open the files, so I have no idea what year SW the files were created in...... Quote
JD Mather Posted September 16, 2010 Posted September 16, 2010 Hey dave, are your clients not willing to export the files ...stl files for you? I don't thing stl would be of much use. STEP (*.stp) probably the easiest to work with. Might be time to upgrade to Inventor 2011 to open later version of SWx files (up to 2010). Quote
shift1313 Posted September 16, 2010 Posted September 16, 2010 I don't thing stl would be of much use. STEP (*.stp) probably the easiest to work with. Might be time to upgrade to Inventor 2011 to open later version of SWx files (up to 2010). yeah ive been sending a lot of files out for rapid proto and have stl on the brain:) Quote
bhamze Posted September 16, 2010 Posted September 16, 2010 I run SW 2010. I can open your files and export them as IGES files. Would this help? Quote
davecuster Posted September 16, 2010 Author Posted September 16, 2010 Absolutely....... The uploader on the site is either not working, or painfully slow.... my direct email is davec@maxmfg.com thanks in advance.... Quote
