Lt Dan's legs Posted September 20, 2010 Posted September 20, 2010 This may not be grread.. I'm trying to (setq p1 (getpoint)) (setq p2 (getpoint ;;window from p1;) make sense? Quote
lpseifert Posted September 20, 2010 Posted September 20, 2010 (setq p1 (getpoint "Pick first point: ")) (setq p2 (getcorner p1 "Pick corner: ")) Quote
Lt Dan's legs Posted September 20, 2010 Author Posted September 20, 2010 I completely forgot about getcorner Thanks!! Quote
alanjt Posted September 20, 2010 Posted September 20, 2010 Just for fun... (defun _grCorner (pt / foo gr) ;; Alan J. Thomspon, 09.20.10 (defun foo (p1 p2) (redraw) (if (apply 'and (mapcar 'vl-consp (list p1 p2))) ((lambda (l d) (mapcar '(lambda (a b) (and a b (grdraw a b 7 d))) l (append (cdr l) (list (last l)))) ) (list p1 (list (car p2) (cadr p1)) p2 (list (car p1) (cadr p2)) p1) (cond ((> (car p1) (car p2)) 1) (0) ) ) ) ) (if (vl-consp pt) (progn (while (eq 5 (car (setq gr (grread T 15 1)))) (foo pt (cadr gr))) (redraw) (cond ((eq 3 (car gr)) (cadr gr))) ) ) ) Quote
Lee Mac Posted September 20, 2010 Posted September 20, 2010 Some funky corners for kicks (defun LM:FunkyGrCorner ( p1 / g ) (while (= 5 (car (setq g (grread 't 13 0)))) (redraw) ( (lambda ( p1 p2 p3 p4 h xa x ) (mapcar '(lambda ( from to ) (grdraw from to -1 h)) (list p1 p2 p3 p4) (list p2 p3 p4 p1)) (mapcar '(lambda ( from ax ) (LM:grCornerpiece from (+ ax xa (/ (* x 5 pi) 4.)) 8 3)) (list p1 p2 p3 p4) (list (angle p1 p2) (angle p2 p3) (angle p3 p4) (angle p4 p1)) ) ) p1 (list (caadr g) (cadr p1)) (cadr g) (list (car p1) (cadadr g)) (if (< (car p1) (caadr g)) 0 1) (angle '(0. 0. 0.) (trans (getvar 'ucsxdir) 0 (trans '(0. 0. 1.) 1 0 t) t)) (if (or (and (< (caadr g) (car p1)) (< (cadr p1) (cadadr g))) (and (< (car p1) (caadr g)) (< (cadadr g) (cadr p1)))) -1 1) ) ) (redraw) (if (listp (cadr g)) (cadr g)) ) (defun LM:grCornerpiece ( p a s c / -s lst r ) ;; © Lee Mac 2010 (setq -s (- s) lst (list (list -s -s) (list 0. 0.) (list (1+ -s) -s) (list 0. -1.) (list -s (1+ -s)) (list -1. 0.) (list -s s) (list 0. 0.) (list (1+ -s) s) (list 0. 1.) (list -s (1- s)) (list -1. 0.) (list -s -s) (list -s s ) (list (1+ -s) -s) (list (1+ -s) s) (list -s (1+ -s)) (list -s (1- s)) ) ) (setq r (/ (getvar 'VIEWSIZE) (cadr (getvar 'SCREENSIZE))) p (trans p 1 3)) (grvecs (cons c (LM:RotatePointsbyMatrix lst '(0. 0. 0.) a)) (list (list r 0. 0. (car p)) (list 0. r 0. (cadr p)) (list 0. 0. r 0.) (list 0. 0. 0. 1.) ) ) ) ;;--------------=={ Rotate Points by Matrix }==---------------;; ;; ;; ;; Performs a Rotation transformation on a list of points ;; ;;------------------------------------------------------------;; ;; Author: Lee McDonnell, 2010 ;; ;; ;; ;; Copyright © 2010 by Lee McDonnell, All Rights Reserved. ;; ;; Contact: Lee Mac @ TheSwamp.org, CADTutor.net ;; ;;------------------------------------------------------------;; ;; Arguments: ;; ;; PointList - list of points to be rotated ;; ;; BasePoint - base point for rotation (in CS of PointList) ;; ;; rAngle - angle of rotation ;; ;;------------------------------------------------------------;; (defun LM:RotatePointsByMatrix ( PointList BasePoint rAngle ) ;; © Lee Mac 2010 ( (lambda ( Matrix / BaseVector ) (setq BaseVector (mapcar '- BasePoint (mxv Matrix BasePoint))) (mapcar '(lambda ( point ) (mapcar '+ (mxv Matrix point) BaseVector)) PointList) ) (list (list (cos rAngle) (sin (- rAngle)) 0.0) (list (sin rAngle) (cos rAngle) 0.0) (list 0.0 0.0 1.0) ) ) ) (defun mxv ( m v ) (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m) ) Quote
muthu123 Posted September 23, 2010 Posted September 23, 2010 Dear lee, how you are thinking like this?... you made me excited with your code... Keep it up.. Regards, Muthu Quote
