domyrat Posted September 12, 2008 Posted September 12, 2008 I have this block (in attachment). It's a door, and i need different sizes, 110 width, 214.5 height 101 width, 214.5 height 101 width, 203.5 height 106 width, 198.5 height 91 width, 198.5 height 71 width, 198.5 height Any chance how to resize it to correct size for all door? Help please. !vrata-blok.dwg Quote
shift1313 Posted September 12, 2008 Posted September 12, 2008 if you do some simple math you can easily resize it. Select your object and right click, go to the properties menu. Under the available information there is a section called geometry. There is a scale x, y and z. for instance, your drawing is 110wide, if you want it 101 you simply do 101/110 = .918181818 etc. punch this number in your ScaleX box and it will scale the x down to this dimension. Be careful that you pay attention to the other elemens of the drawing such as the door handle. for instance scaling the x down to 101 will make your door handle go from 12 wide to 11.02. If this file is merely for reference, this may work for you but otherwise you will need to model the door handle as a seperate layer and not part of the door. Quote
Bogbadbob658 Posted September 14, 2008 Posted September 14, 2008 Don't forget you will have the same problem with door frame as you do with the door handle. i.e it will be distorted due to the scaling. You could create a model of each sizie and put them into a dynamic block and use a lookup to display the required one but this will be memory hungry if you have a lot of doors to show. Is there a reason why can't use different block for each size? Quote
Cad64 Posted September 14, 2008 Posted September 14, 2008 I have modified your thread title. You should always try to be as specific as possible when naming your threads. :wink: Quote
