Hi,
I am wondering if there is a block insert macro that can let the user choose the block they will insert from a specific folder of drawings.
i.e. Rather than:
^c^c_.insert;"C:/pathname/blockname.dwg";
I'm looking for something more along the lines of
^c^c_.insert;"C:/pathname/";
(but that doesn't seem to work)
Or, my other idea -- is there a way to use getfiled in a basic macro combined with the insert command?
I have a LISP routine set up for my AutoCAD users, but am trying to create a similar functionality for my AutoCAD LT users. And unfortunately I don't know much about macros.
Thanks in advance for any suggestions! :)
Edit: Congrats on your first post, and welcome to the forums!
Try using a tilda "~" in lieu of the filepath. :wink:
^C^C^P._insert;"~";
Edit: Macros can be written using DIESEL, or LISP... You could also use getfiled, to set specific parameters (i.e., default directory, and .dwg file extension) if desired.
  • 2 weeks later...
hi,
Is the location of the block in your "support file search path"?:wink:
peace out...
kool
How is that relevant to the OP's request..? :?
Admittedly, the Macro I provided does not specify a folder, but instead allows the user to 'navigate' to any folder. The only other way I know how to offer blocks from a specific folder, is to create a Tool Palette for blocks in said folder. Just be sure to add new blocks (those added after you create the Tool Palette) to said Tool Palette. :wink:
Its far better to have a little picture of your block in a group that you can pick from rather than remembering its name, we use the old fashioned slides in a pull down these are grouped to common objects 200+ blocks 9 menu choices then multi page choice every body here likes it, but the modern way is like Renderman look into tool palletes these can be called from 1 line in a menu.
Theres lots of posts about tool palletes
Yeah, we still have some legacy tools which utilize slides. The problem with slides is this:
Slide menus are probably not a good idea going forward. The reason is that slide menus work best with slide libraries and the utility for creating slide libraries has not been updated in over a decade. I haven't even tried to run in on Win7 64-bit so see if it will work or if it is included in AutoCAD installs any more.
I would suggest that if your users want icon-based buttons for content, that you use either Ribbon buttons or Tool Palettes.
Source: http://forums.augi.com/showthread.php?p=1101435#post1101435
