Extracting attributes to Excel
When extracting attributes to an Excel spreadsheet the drawing title block is generally spread across three columns ie one column per attribute, I can be combined the columns after entering the spread sheet using concatenate, is it possible to automate this.
I wish to do hundreds of drawings at a time, autocad 10 extracts attributes for you, im just trying to improve the layout of the results in the spreadsheet.
Start your search here:
(defun c:FOO (/ excelApp)
 (vl-load-com)
 (if (setq excelApp (vlax-get-or-create-object "Excel.Application"))
     (textpage)
     (vlax-dump-object excelApp T)
     (vlax-release-object excelApp)))
 (princ))
This will display a list of the properties and methods available to the Excel application.
Happy hunting, and good luck!
