PLEASE help me with the 2009 AutoCAD
Elevations. OK. What is the exact nature of the assignment? Make a site plan and locate the spot elevations in the correct positions? That would require angle and distance from a known survey position. How is that position being established? What point did the surveyor use to establish the 0 deg 00 min 00 sec sight line? Are angles turned to the right only? Are deflection angles used? After plotting the points representing the elevations are you supposed to come up with the contours? If so, what contour interval will be used? Yep, a few more questions need to be answered.
Where in Canada are you located?
  • Replies 24
  • CAD-LOVER0208
    10
  • ReMark
    8
  • Dipali
    3
  • Cad64
    2
Posted Images
first, I live in Toronto
second.. i found the answers for all of your questions, :wink: ..
i am working on it, when i finish i'll post it here...
it's actually a "big" assignment and it is due on the 25th of september.. the site plan was nothing, i mean what i did was right, because the teacher wanted to see just the sketch of the thing we are going to work on.. He explained it all, but i can't explain it here sorry... but i can show it to you later.. i can sketch, but it's hard for me to explain.. i know i confused you guys.. i'm sorry. :oops:
just wait for me and i'll show you later my work.. :wink:
thanks :cute:
OK. Then I guess we'll all just hold off on giving any more advice and await the outcome. I'd be interested in seeing the end result. Good luck.
  • 1 month later...
helloooo ReMark and everyone in this great site.
i'm back, i fixed all the problems and i have my dwg almost ready, but i have a question about the solid hatching, should i ask the question here or in a new thread ???
thanks for everything :)
CAD-LOVER:
I would suggest you post a new thread. Glad to hear you are making progress.
