good_m Posted February 10, 2006 Posted February 10, 2006 I've just started playing with autolisp and here's a problem that I'm having. I want the lisp to draw a construction line base on a point, trim numberous lines to it and then erase it. The onjly problem that I'm having is that it trims the wrong side of the line...can someone please help the code is below. (defun c:trp (/ pt ui xl ob sel fil) (setq pt (getpoint)) (initget "VERtical HORizontal _VER HOR") (command "_xline" (setq ui (getkword "\nWhich direction? (VERtical/HORizontal)")) pt "") (setq xl (entlast)) (setq sel (ssget w)) (command "_trim" xl "" \ "") (command "_erase" xl "")(princ)) Quote
rkmcswain Posted February 10, 2006 Posted February 10, 2006 I've just started playing with autolisp and here's a problem that I'm having. I want the lisp to draw a construction line base on a point, trim numberous lines to it and then erase it. The onjly problem that I'm having is that it trims the wrong side of the line...can someone please help the code is below. (defun c:trp (/ pt ui xl ob sel fil) (setq pt (getpoint)) (initget "VERtical HORizontal _VER HOR") (command "_xline" (setq ui (getkword "\nWhich direction? (VERtical/HORizontal)")) pt "") (setq xl (entlast)) (setq sel (ssget w)) (command "_trim" xl "" \ "") (command "_erase" xl "")(princ)) Try this: (defun c:trp (/ pt ui xl) (setq pt (getpoint "\nPick Point: ")) (initget "V H") (command "._xline" (setq ui (getkword "\nWhich direction? (Vertical/Horizontal)")) pt "" ) (setq xl (entlast)) (command "._trim" xl "") (while (eq 1 (logand (getvar "CMDACTIVE") 1)) (command PAUSE) ) (entdel xl) (princ) ) Quote
good_m Posted February 10, 2006 Author Posted February 10, 2006 Thanks alot....it works great. I was hoping that sometime if you have the time you could explain what it means...ie how you did it. Like I said I've just started with AutoLISP and I still have a whole lot to learn and you can't really ask books "how do you do that?". Thanks again for the response! Mike Quote
rkmcswain Posted February 11, 2006 Posted February 11, 2006 (defun c:trp (/ pt ui xl) (setq pt (getpoint "\nPick Point: ")) (initget "V H") (command "._xline" (setq ui (getkword "\nWhich direction? (Vertical/Horizontal)")) pt "" ) (setq xl (entlast)) (command "._trim" xl "") (while (eq 1 (logand (getvar "CMDACTIVE") 1)) (command PAUSE) ) (entdel xl) (princ) ) Another method would be to calculate the trim points and alter the endpoints of the lines that are "trimmed". This way you don't have to call (command "._trim"....) Quote
good_m Posted February 11, 2006 Author Posted February 11, 2006 Thanks a lot RKM. All of that stuff makes sense to me except for this part: (eq 1 (logand (getvar "CMDACTIVE") 1)) (command PAUSE) I guess I just don't understand how the "eq 1", "logand" and CMDACTIVE actions work. Thanks for everything though! Mike Quote
David Bethel Posted February 11, 2006 Posted February 11, 2006 (logand) function Integer bit flag comparison Bit values 0000 = 0 0001 = 1 0010 = 2 0011 = 3 0100 = 4 0101 = 5 0110 = 6 0111 = 7 1000 = 8 1001 = 9 1010 = 10 1011 = 11 1100 = 12 1101 = 13 1110 = 14 1111 = 15 (logand flag bit) ;;;check to see if the bit is set in the flag value ;;;Returns the bit number if T ;;;Returns 0 if nil (logand 5 1) ;;;Returns 1 - the 1 bit is set - 5 = 0101 or 4+1 (logand 5 2) ;;;retruns 0 - the 2 bit is not set So the test would be (if (= (logand 5 1) 1) (then do this) (else do that)) Or (while (eq 1 (logand (getvar "CMDACTIVE") 1)) (command pause)) Which says that while the command is active, pause for user input. I usually use (while (> (getvar "CMDACTIVE") 0) (command pause)) HTH -David Quote
good_m Posted February 11, 2006 Author Posted February 11, 2006 Perfect...now I actually understand what all that means! haha thanks a lot! Quote
David Bethel Posted February 11, 2006 Posted February 11, 2006 Bitflags are fairly elementary computer science entities. An easy way to see them work are with the visibility of edges with 3DFACEs. The flag is contained in the DXF group 70 value. If the first edge is invisible, then the flag 1 bit is set. The 2nd edge sets the 2 bit, 3 edge the 4 bit, 4th edge the 8 bit. So if group 70 = 15, all of the edges are invisible. -David Quote
rkmcswain Posted February 12, 2006 Posted February 12, 2006 Thanks a lot RKM. All of that stuff makes sense to me except for this part: (eq 1 (logand (getvar "CMDACTIVE") 1)) (command PAUSE) I guess I just don't understand how the "eq 1", "logand" and CMDACTIVE actions work. Thanks for everything though! Mike Here is the best explanation I know of... http://tinyurl.com/dnpl5 Quote
guitarguy1685 Posted January 21, 2010 Posted January 21, 2010 a useful thread. It definitely explained quite a bit, however I also brings up more questions...at least for me. I read the post and my question is what "right or left most bit" mean? Here, each digit represents a distinct logical true/falsestate (five significant ones in this number), as shown in this table: Bit 1: FALSE (right-most bit) Bit 2: TRUE Bit 3: TRUE Bit 4: FALSE Bit 5: TRUE (left-most bit) Quote
Lee Mac Posted January 21, 2010 Posted January 21, 2010 I believe the red is right-most: 10110110101[b][color=Red]1[/color][/b] Quote
shailesh Posted November 21, 2011 Posted November 21, 2011 From wer i can download AutoLIPS Plz help Quote
