Tiger Posted September 29, 2010 Posted September 29, 2010 Hey Folks, I have two new LIN-files that are giving me grief. I have put them in the same folder as the ACADISO.lin and head into AutoCAD and the Layer Manager and try to load the linetype. When I come to the Linetype load box it just says: [ATTACH]23371[/ATTACH] when I count the lines, line 14 is the first line with a linetype, they all look the same along the lines of this: *BH90-PMA-V,Projekterad Vattenledning. Metod A. A,5,["V",STANDARD,X=0,Y=.5],5 Does anyone see what is wrong? I know next to nothing about linetypes... Quote
NBC Posted September 29, 2010 Posted September 29, 2010 (edited) Is it anything to do with the full stops in the first line of the code you posted ? vair strange, I just created that linetype using your code, and it worked fine. Edited September 29, 2010 by NBC tested out the code, but works ok Quote
Tiger Posted September 29, 2010 Author Posted September 29, 2010 Ok, mistake is one me, I tried a linetype from the second LIN-file but the one I posted I got from the first - and specific one works for me too. Here's one that I am sure that I can't get to work - anyone wanna play Fine Five Faults? *BH90-BMA-V,Befintlig Vattenledning. Metod A. A,10,["V",STANDARD,X=0,Y=.5,S=2],10,[bEFINTLIG,BH90K.SHX,S=0.5,X=-1.5,Y=-0.75] And I think I spotted the culprit: BH90K.shx... Quote
NBC Posted September 29, 2010 Posted September 29, 2010 Looks like it could be a culprit.. Do you have that particular shape file? If so, is it's location in any of the folders contained within your Support File Search Path ? Quote
Tiger Posted September 29, 2010 Author Posted September 29, 2010 I don't have it, I will request that too from the client and get back to you. Quote
