Is there a variable that I can use to set the Line Space Style of leaders to "exactly"??
Have you read the procedure Create and Modify Leaders in your Help file? It refers to alignment and spacing. Hope that addresses your problem. If not, you know where to find us. We'll all be down by the watercooler.
Thanks Lads, I checked those out and there is nothing there that I could see. I know if you click on the leader and go to the properties tab then it can be changed there. So I thought there may be some variable to control that.
We are talking MultiLeaders correct?
Hmmm....it appears that MLEADERALIGN using the Spacing option works after-the-fact. That won't do in your case.
I read somewhere LeeMac that that is to do with Text only and does not apply to dims and leaders.
Controls the type of line spacing used in multiline text. At Least adjusts line spacing based on tallest characters in a line. Exactly uses the specified line spacing, regardless of individual character sizes.
1    At Least
2    Exactly
AutoCad does not at this time have a variable which would allow the user to set that preference.
Is there a way I can create a selection set of all leaders using qselect with a lisp?
Yes, it's called forget QSelect and read up on SSGet. :wink:
SSGET
the underscore (_) is needed with W, F, WP, :S but not with X, A, C, CP, I, L, P, :E ...
(ssget '(2 2))
Create a selection set of the object passing through (2,2):
+.  The undocumented “+.” mode forces (ssget) to remain in “point” mode, similar to
   setting PickAuto to 0.... the "+." puts (ssget) into "point" mode. It helps the ":S"
   single-mode act just like (entsel) by avoiding implied selection windows.
A  All like "X" but filters frozen out
  Selects all objects on thawed layers.
B  Box
  Selects all objects inside or crossing a rectangle specified by two points. If
  the rectangle's points are specified from right to left, Box is equivalent to
  Crossing. Otherwise, Box is equivalent to Window.
C  Crossing  Simular to Window selection
  Selects objects within and crossing an area defined by two points. A crossing
  selection is displayed as dashed or otherwise highlighted to differentiate it
  from window selection. Specifying the corners from right to left creates a
  crossing selection. *** (Specifying the corners from left to right creates a window
  selection.)  (ssget "_C" '(0 0) '(1 1))
  Caution: the area must be on the screen for this to work properly - CAB
CP Crossing Polygon
  Selects objects within and crossing a polygon defined by specifying points. The
  polygon can be any shape but cannot cross or touch itself. AutoCAD draws the
  last segment of the polygon so that it is closed at all times. CPolygon is not
  affected by the PICKADD system variable.
  (ssget "_CP" '((1 1)(3 1)(5 2)(2 4)))
  Example with filters (ssget "_CP" '(Point list) '(Filter List))
  (setq ss (ssget "_CP" '((0 0)(10 0)(10 10)(0 10)) '((0 . "INSERT") (66 . 1))  ))
  (vl-cmdf "._zoom" "_E") ; Extents
 Duplicates OK, else duplicates are ignored
:E Everything in aperture
  Everything within the cursor's object selection pickbox.
F Fence
 Selects all objects crossing a selection fence. The Fence method is similar to
 CPolygon except that AutoCAD does not close the fence, and a fence can cross
 itself. Fence is not affected by the PICKADD system variable.
G Groups
 Selects all objects within a specified group.
I Implied
 Implied selection (objects selected while PICKFIRST is in effect).
L Last
 Last visible object added to the database
:L Rejects locked layers
M  Multiple
  Specifies multiple points without highlighting the objects, thus speeding up
  the selection process for complex objects. The Multiple method also selects two
  intersecting objects if the intersection point is specified twice.
:N Nested
  Call ssnamex for additional information on container blocks and transformation
  matrices for any entities selected during the ssget operation. This additional
  information is available only for entities selected via graphical selection
  methods such as Window, Crossing, and point picks.
  Unlike the other object selection methods, :N may return multiple entities with
  the same entity name in the selection set. For example, if the user selects a
  subentity of a complex entity such as a BlockReference, PolygonMesh, or old
  style polyline, ssget looks at the subentity that is selected when determining
  if it has already been selected. However,  ssget actually adds the main entity
  (BlockReference, PolygonMesh, etc.) to the selection set. The result could be
  multiple entries with the same entity name in the selection set (each will have
  different subentity information for ssnamex to report).
P  Previous
  Selects the most recent selection set. The Previous selection set is cleared by
  operations that delete objects from the drawing. AutoCAD keeps track of whether
  each selection set was specified in model space or paper space. The Previous
  selection set is ignored if you switch spaces.
 Rejects Viewport
:R Allows entities in a long transaction to be selected.
:S Force single object selection only
:U Enables subentity selection - 2006+
Cannot be combined with the  duplicate (":D") or nested (":N")  selection modes.
In this  mode, top-level  entities are  selected by  default, but  the user  can
attempt  to  select  subentities  by pressing  the  CTRL  key  while making  the
selection. This option  is supported only  with interactive selections,  such as
window, crossing, and polygon. It is  not supported for all, filtered, or  group
selections.
:V Forces subentity selection - 2006+
Treats all interactive,  graphic selections performed  by the user  as subentity
selections. The returned  selection set contains  subentities only. This  option
cannot be combined with the  duplicate (":D") or nested (":N")  selection modes.
This option is  supported only with  interactive selections, such  as window and
crossing. It is not supported for all, filtered, or group selections.
W  Window
  Selects all objects completely inside a rectangle defined by two points.
  Specifying the corners from left to right creates a window selection.
  (Specifying the corners from right to left creates a crossing selection.)
WP Window Polygon
  Selects objects completely inside a polygon defined by points. The polygon can
  be any shape but cannot cross or touch itself. AutoCAD draws the last segment of
  the polygon so that it is closed at all times. WPolygon is not affected by the
X  Extended search (search whole database)
  Entire database. If you specify the X selection method and do not provide a
  filter-list, ssget selects all entities in the database, including entities on
  layers that are off, frozen, and out of the visible screen.
  Also at the command prompt "Select objects:" you can enter
  Add, Remove, Undo,
:U Enables subentity selection. Cannot be combined with the duplicate (":D") or
  nested (":N") selection modes. In this mode, top-level entities are selected by
  default, but the user can attempt to select subentities by pressing the CTRL key
  while making the selection. This option is supported only with interactive
  selections, such as window, crossing, and polygon. It is not supported for all,
:V Forces subentity selection. Treats all interactive, graphic selections
  performed by the user as subentity selections. The returned selection set
  contains subentities only. This option cannot be combined with the duplicate
  (":D") or nested (":N") selection modes. This option is supported only with
  interactive selections, such as window and crossing. It is not supported for
Systen Var
 PICKADD controls whether subsequent selections replace the current selection set or add to it.
lol :lol: :lol:
