i am in desperate need of help (subdivide a line & arc into multiple points )
apachiee
 Share
hello to all,
could anyone post me a lisp file which can subdivide a line & arc into multiple points as i want, means if a line has a length of 100m i can subdivide it into 10m interval without breaking points, making a line of 100m with 11 points in it... same as with arc too..
i would really appreciate, ur efforts...
thanks...
Not sure if this is what you are looking for?
One from my archive...
;;------------------------=={ Segs }==------------------------;;
;;  Divides selected objects into an LWPolyline with a        ;;
;;  specified number of segments                              ;;
;;  Author: Lee McDonnell, 2010                               ;;
;;  Copyright © 2010 by Lee McDonnell, All Rights Reserved.   ;;
;;  Contact: Lee Mac @ TheSwamp.org, CADTutor.net             ;;
(defun c:Segs ( / *error* _StartUndo _EndUndo doc ss )
 (vl-load-com)
 ;; © Lee Mac 2010
 (defun *error* ( msg ) (and doc (_EndUndo doc))
       (princ (strcat "\n** Error: " msg " **")))
 (defun _StartUndo ( doc ) (_EndUndo doc)
   (vla-StartUndoMark doc)
 (defun _EndUndo ( doc )
   (if (= 8 (logand 8 (getvar 'UNDOCTL)))
     (vla-EndUndoMark doc)
 (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)) *segs (cond ( *segs ) ( 10 )))
 (if
   (and
     (setq ss (ssget "_:L" '((0 . "ARC,CIRCLE,LWPOLYLINE,SPLINE,LINE,ELLIPSE"))))
     (progn (initget 6)
       (setq *segs (cond ((getint (strcat "\nSpecify Number of Segments <" (itoa *segs) "> : "))) ( *segs )))
     (lambda ( j / e inc i pts ) (_StartUndo doc)
       (while (setq e (ssname ss (setq j (1+ j))))
           (lambda ( inc i / pts )
             (repeat (1+ *segs)
               (setq pts (cons (trans (vlax-curve-getPointatDist e (* (setq i (1+ i)) inc)) 0 e) pts))
             (if
               (entmake
                 (append
                   (list
                     (cons 0   "LWPOLYLINE")
                     (cons 100 "AcDbEntity")
                     (cons 100 "AcDbPolyline")
                     (cons 90 (length pts))
                     (cons 38 (caddar pts))
                     (cons 70 0)
                   (vl-remove-if 'null
                     (mapcar
                       (function (lambda ( d ) (assoc d (entget e)))) '(6 8 39 48 210)
                   (mapcar (function (lambda ( a ) (cons 10 a))) pts)
               (entdel e)
           (/ (vlax-curve-getDistatParam e (vlax-curve-getEndParam e)) (float *segs)) -1
       (_EndUndo doc)
     -1
thank u very much Lee, it really has helped me alot only thing i have to do is to edit the drawing entity into polyline & rest it is working fine, thank u very much again... bro ... :):):D
I'm also a bit confused. From your OP it doesn't sound as if you want a segmented pline. Maybe I'm just missing something.
Otherwise I'd also state: use Measure or Divide. It places point entities along the line / arc / circle / pline / etc. Changing PDMode to something else than 0 makes the points visible as other figures (e.g. PDMode=3 means a point looks like a X) Or you can tell it to place a block instead, rotated along the path or not - usually how I'd have marked chainage points.
 Share
