AutoLISP to lock viewports, change visualstyle and set to specific layer
Oh yeah, thanks - shame there isn't a way to retrieve the LWPolyline object through VL :ouch:
  • Replies 26
  • alanjt
    10
  • Lee Mac
    6
  • SuperCAD
    4
  • BlackBox
    4
True, but I'm just glad to have a seemingly easy way to actually access the data/object(s).
  • 1 year later...
This a a great script as is, but can someone tell me how to get it to set the "Shade Plot" to "Hidden" along with the other changes it makes?
Thanks,
Ben
Edit:
Nevermind. I figured it out that adding (vla-put-ShadePlot vport 2) after (vla-put-VisualStyle vport 1) does exactly what I need.
Ben
Edited by No1BroncoFan
I am sorry, I did not read all 3 pages.
this is the lisp i have been using to lock all the VP's in the drawing.
 (defun C:LockAllVp (/ ss otab)
(setq otab (getvar "ctab"))
(foreach item (layoutlist)
(setvar "ctab" item)
(setq ss (ssget "x" '((0 . "VIEWPORT"))))
(command ".-vports" "Lock" "On" ss "")
);foreach
(setvar "ctab" otab)
);defun
i hope this can help someone out.
);foreach
);defun
Baker, this may be of interest; it will be a lot faster since it doesn't have to cycle through each layout. It give the option to lock or unlock all viewports.
(defun c:LV (/ ss)
 ;; Lock/Unlock all viewports
 ;; Alan J. Thompson, 09.10.09
 (if (setq ss (ssget "_X" '((0 . "VIEWPORT"))))
   ((lambda (lock)
      (vlax-for x (setq ss (vla-get-activeselectionset
                             (cond (*AcadDoc*)
                                   ((setq *AcadDoc* (vla-get-activedocument
                                                      (vlax-get-acad-object)
        (vla-put-displaylocked x lock)
      (vla-delete ss)
      (and (zerop (getvar 'tilemode)) (vla-put-mspace *AcadDoc* :vlax-false))
      (princ (strcat "\nAll Viewports have been "
                     (if (eq lock :vlax-true)
                       "Locked!"
                       "Unlocked!"
     (if (eq "Yes"
             (progn (initget 0 "Yes No")
                    (cond ((getkword "\nLock Viewports? [Yes/No] <Yes>: "))
                          ("Yes")
       :vlax-true
       :vlax-false
   (alert "\nNo viewports in drawing.")
A few more that I posted at AUGI a while back...
[color=GREEN];; Lock Selected Viewport[/color]
([color=BLUE]defun[/color] c:vpl [color=BLUE]nil[/color]
   ([color=BLUE]if[/color] (SSVPLock ([color=BLUE]ssget[/color] [color=MAROON]"_+.:E:S:L"[/color] '((0 . [color=MAROON]"VIEWPORT"[/color]))) [color=BLUE]:vlax-true[/color])
       ([color=BLUE]princ[/color] [color=MAROON]"\n--> Viewport Locked."[/color])
   ([color=BLUE]princ[/color])
[color=GREEN];; Unlock Selected Viewport[/color]
([color=BLUE]defun[/color] c:vpu [color=BLUE]nil[/color]
   ([color=BLUE]if[/color] (SSVPLock ([color=BLUE]ssget[/color] [color=MAROON]"_+.:E:S:L"[/color] '((0 . [color=MAROON]"VIEWPORT"[/color]))) [color=BLUE]:vlax-false[/color])
       ([color=BLUE]princ[/color] [color=MAROON]"\n--> Viewport Unlocked."[/color])
[color=GREEN];; Lock All Viewports[/color]
([color=BLUE]defun[/color] c:vpla [color=BLUE]nil[/color]
   (SSVPLock ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color] '((0 . [color=MAROON]"VIEWPORT"[/color]))) [color=BLUE]:vlax-true[/color])
   ([color=BLUE]princ[/color] [color=MAROON]"\n--> All Viewports Locked."[/color])
[color=GREEN];; Unlock All Viewports[/color]
([color=BLUE]defun[/color] c:vpua [color=BLUE]nil[/color]
   (SSVPLock ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color] '((0 . [color=MAROON]"VIEWPORT"[/color]))) [color=BLUE]:vlax-false[/color])
   ([color=BLUE]princ[/color] [color=MAROON]"\n--> All Viewports UnLocked."[/color])
([color=BLUE]defun[/color] SSVPLock ( ss lock [color=BLUE]/[/color] i )
   ([color=BLUE]if[/color] ss
       ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] i ([color=BLUE]sslength[/color] ss))
           ([color=BLUE]vla-put-displaylocked[/color] ([color=BLUE]vlax-ename->vla-object[/color] ([color=BLUE]ssname[/color] ss ([color=BLUE]setq[/color] i ([color=BLUE]1-[/color] i)))) lock) [color=BLUE]t[/color]
([color=blue]vl-load-com[/color])
  • 2 weeks later...
);foreach
);defun
oK, SO THIS WORKS FOR ME (THANKS FOR POSTING) **sorry, allcaps***
Ok, I've been fighting to get this lisp to load auto via my acaddoc.lsp but its not working....
i basically have the following in my acaddoc.lsp (simplified):
(load "[i]lisphere.lsp[/i]")
(command "[i]commandhere.lsp[/i]")
(setvar "[i]variablehere.lsp[/i]")
Its pretty basic since my brain is pretty basic.
I also tried autoload, verified the lisp is in the cad2010 directory, even tried throwing it into my local setting.....directory. nothing.
My other lsp will work, just not this one. Any suggestions?
(autoload "vplock" '("lv" "vplock"))
ASIDE:
I was also wondering is it possible for a file to autoload all lisps in a specific folder (local or network) without typing 100+ lines in the lsp??
I found some older posts but i wanted to avoid ressurrecting a 2year old post:shock:....
***EDIT***
Lee, I was able to get yours to work...
Edited by N_461
partial solution
