Guest balajibth84 Posted October 6, 2010 Share Posted October 6, 2010 Hai here Balaji..Actually now i am using the lisp for join(Tracking method)..While i am Join the 3 continues line(Line or Polyline) my lisp creating the unwanted vertex...But i want only 2 endpoint and midpoint vertex only ...So i want remove that unwanted remaining vertex.....Can you edit this lisp???? (defun c:j () (setvar "cmdecho" 0) (setq lines (ssget (list (cons 0 "LINE,ARC,LWPOLYLINE,POLYLINE")))) ;POLYLINE added 300910 - will crash with 3D POLYLINES (if lines (progn (while (> (sslength lines) 0) (if (= (cdr (assoc 0 (entget (ssname lines 0)))) "LWPOLYLINE") (progn (command "pedit" (ssname lines 0) "j" lines "" "X") (ssdel (ssname lines 0) lines) ) (command "pedit" (ssname lines 0) "y" "j" lines "" "X") ) (setq lines2 (ssadd)) (setq cnt 0 len (sslength lines)) (while ( (if (entget (ssname lines cnt)) (setq lines2 (ssadd (ssname lines cnt) lines2)) ) (setq cnt (1+ cnt)) ) (setq lines lines2) ) (princ "\n......Tada!!") ) (princ "\n....Doh!!") ) (setvar "cmdecho" 1) (princ) ) Quote Link to comment Share on other sites More sharing options...
JohnM Posted October 6, 2010 Share Posted October 6, 2010 What you are asking for is possible but will require a bit of programming to take in count all the possible scenarios. Sounds like it would be easer just to trace over the lines with a polyline then erase the old ones. Example if you draw two polylines one left to right and the other right to left then the starting points of each polyline is different. So if you have a polyline and a line connected end to end at the same angle to will have to determine where the start point is. This is easy if everything is drawn left to right or right to left but complicated if not. But I did find this cool program free on a site and it works well for removing a vertex. I don’t know who wrote it but they deserve credit http://www.xanadu.cz/en/download.asp?file=AddV Quote Link to comment Share on other sites More sharing options...
Guest balajibth84 Posted October 7, 2010 Share Posted October 7, 2010 What you are asking for is possible but will require a bit of programming to take in count all the possible scenarios. Sounds like it would be easer just to trace over the lines with a polyline then erase the old ones.Example if you draw two polylines one left to right and the other right to left then the starting points of each polyline is different. So if you have a polyline and a line connected end to end at the same angle to will have to determine where the start point is. This is easy if everything is drawn left to right or right to left but complicated if not. But I did find this cool program free on a site and it works well for removing a vertex. I don’t know who wrote it but they deserve credit http://www.xanadu.cz/en/download.asp?file=AddV I tried ..But i cannt able to Find....Can u give exact path plz????i want to knw that lisp join+Remove vertex both are combined????bcoz 2 command we want use means better we will use cad actual command...... Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 7, 2010 Share Posted October 7, 2010 Is this your code? Please read the Code Posting Guidelines: http://www.cadtutor.net/forum/showthread.php?9184-Code-posting-guidelines Quote Link to comment Share on other sites More sharing options...
Demesne Posted October 7, 2010 Share Posted October 7, 2010 I posted that lisp a few days ago. If all you lines are 'in-line' i.e. following the same angle and at the same height then try this lisp. It will work even if the lines are drawin in different directions. ;linj - joins a series of lines into one line - does not check angles or joins ; ; (defun c:linj () (setvar "cmdecho" 0) (if (setq sset (ssget (list (cons 0 "line")))) (progn (setq cnt 0 ln (sslength sset)) (setq la (cdr (assoc 8 (entget (ssname sset 0))))) (setq elist nil nlist nil) (command "undo" "g") (while (< cnt ln) (setq e1 (entget (ssname sset cnt)) elist (append elist (list (setq p1e (car (trans (cdr (assoc 10 e1)) 0 1)))(setq p2e (car (trans (cdr (assoc 11 e1)) 0 1))))) nlist (append nlist (list (setq p1n (cadr (trans (cdr (assoc 10 e1)) 0 1)))(setq p2n (cadr (trans (cdr (assoc 11 e1)) 0 1))))) cnt (1+ cnt) ) ) (setq mae (apply 'max elist) mie (apply 'min elist) man (apply 'max nlist) miin (apply 'min nlist) ) (if (< p1e p2e) (if (< p1n p2n) (entmake (list (cons 0 "line") (cons 8 la) (cons 10 (trans (list mie miin 0.0) 1 0)) (cons 11 (trans (list mae man 0.0) 1 0)) ) ) (entmake (list (cons 0 "line") (cons 8 la) (cons 10 (trans (list mie man 0.0) 1 0)) (cons 11 (trans (list mae miin 0.0) 1 0)) ) ) ) (if (< p1n p2n) (entmake (list (cons 0 "line") (cons 8 la) (cons 10 (trans (list mae miin 0.0) 1 0)) (cons 11 (trans (list mie man 0.0) 1 0)) ) ) (entmake (list (cons 0 "line") (cons 8 la) (cons 10 (trans (list mae man 0.0) 1 0)) (cons 11 (trans (list mie miin 0.0) 1 0)) ) ) ) ) (command "erase" sset "") (command "undo" "end") ) ) (setvar "cmdecho" 1) (princ) ) Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 7, 2010 Share Posted October 7, 2010 I posted that lisp a few days ago. You should put your name on it then, so when people re-post it, everyone will know who wrote it. Just like an artist signing his paintings, you should sign your code. Quote Link to comment Share on other sites More sharing options...
