What is going wrong? (copy attributes from mspace to pspace lisp)
It all works fine if you do it by hand, but if I run it all at once in a script it just deletes all attributes :geek:
The stranged part is it deletes the attribute in the mspace template, and I only copy and not modify the attributes in mspace.
Edit: it looks like catt and patt are not working in script when activated by selection. Some one any idea why? I didn't made that lisp and I am not really familiar in visuallisp.
Edit2: Stitching catt and patt together gived the same results.
(defun c:test8(/ blks)
(command "mspace")
(sssetfirst nil (ssget "_x" '((0 . "INSERT")(2 . "Template"))))
;(c:catt)
 (cattt)
(setq blks (ssget "_x" '((0 . "INSERT")(2 . "Template"))))
(command "zoom" "o" blks "")
;(command "erase" blks "")
(command "pspace")
;(c:patt)
 (pattt)
(command "zoom" "all")
;I didn't make this part!!!
(defun cattt(/ sSet)
 ;(changeTags)
 (vl-load-com)
 (princ "\n<<< Select block to copy attributes >>>")
 (if
   (setq sSet(ssget "_:S" '((0 . "INSERT")(66 . 1))))
     (setq cBl(vlax-ename->vla-object(ssname sSet 0)))
     (vl-bb-set 'atLst(cons
		 (vla-get-Name cBl)
		   (mapcar '(lambda(x)
		    (vla-get-TextString x))
		       (vlax-safearray->list
	                 (vlax-variant-value
			   (vla-GetAttributes
			     cBl))))))
     (princ "\n<<< Attribute value(s) were copied >>>")
     ); end progn
   (princ "\n>>> This isn't block with attribute(s)! <<< ")
   ); end if
 ); end of c:catt
(defun c:catt () (cattt))
;**** Paste attributes values to multiple blocks ****
(defun pattt(/ sDat dLst fLst blSet)
 (vl-load-com)
 (if
   (setq sDat(vl-bb-ref 'atLst))
     (setq fLst(list '(0 . "INSERT")(cons 2(car sDat)) '(66 . 1))
    dLst(cdr sDat)
    ); end setq
     (princ(strcat "\n<<< Current block to paste is '" (car sDat) "' >>> "))
      (if
(setq blSet(ssget fLst))
  (foreach bl (mapcar 'vlax-ename->vla-object
                      (vl-remove-if 'listp
                        (mapcar 'cadr(ssnamex blSet))))
    (mapcar 'vla-put-TextString
	     (vlax-variant-value
	       (vla-GetAttributes bl)))dLst)
    ); end foreach
 (princ "\n>>> Nothing selected! <<< ")
); end if
     ); end progn
   (princ "\n >>> There isn't attributes datas to paste! <<< ")
   ); end if
 ); end of c:patt
(defun c:patt () (pattt))
Edited by CADkitt
How are you '[running] it all at once in a script'... Do you mean with an .SCR file?
Or do you simply mean that you tried running one command (i.e., c:TEST8 ), which does all steps at once?
I just want to run it all at once with a cmd but I need to check if it went good, so using scr wouldn't work.
It's gonna be part of a bigger lisp file.
Thanks for clarifying... your original discription was a bit confusing (to me).
I already updated the grammar :)
I think it is going wrong at the selection sets, maybe I should change them in catt an patt.
