Hi everyone,
I'm trying to explode some blocks in one layer with the following code
(defun c:440 ()
(ssget "x" '((0 . "insert")(8 . "440_xref")))
(command "explode" "p" "")
I get the following error:
Command: 440
explode
Select object: p
*Invalid selection*
Expects a point or Last/ALL/Group
; error: Function cancelled
I know it's a fairly simple action and I've even tried it with a scrip (using ssx) but when explode tries to get the previous selection it doesn't recognize it.
Any ideas what's going on?
thanks
You may need to use something like this:
(defun c:440 ( / *error* ss qf )
 (defun *error* ( msg )
   (and qf (setvar 'QAFLAGS qf))
       (princ (strcat "\n** Error: " msg " **")))
 (if (setq ss (ssget "_X" '((0 . "INSERT") (8 . "440_xref"))))
     (setq qf (getvar 'QAFLAGS))
     (setvar 'QAFLAGS 5)
     (command "_.explode" ss "")
Or, using VL:
(defun c:440 ( / ss )
 (vl-load-com)
 (if (ssget "_X" '((0 . "INSERT") (8 . "440_xref")))
     (vlax-for o
       (setq ss
         (vla-get-ActiveSelectionSet
           (vla-get-ActiveDocument
             (vlax-get-acad-object)
       (if
         (not
           (vl-catch-all-error-p
             (vl-catch-all-apply 'vla-explode (list o))
         (vla-delete o)
     (vla-delete ss)
{ Untested }
I gather that QAFLAGS is the missing link in my script (still trying to figure out what they are, although I gather that they prevent the script from selecting more than 1 object at the time)
Doing a bit of reading, some say qaflags should be in 1, but on your script and in another thread I read 5.
Any difference?
Any difference?
Both should work, bit-4 suppresses alert boxes also.
Small addition
From the help about command Explode
Note: If you're using a script or an ObjectARX® function, you can explode only one object at a time.
(defun c:440 ( / *error* ss qf i )
 (if (setq ss (ssget "_X" (list '(0 . "INSERT")'(8 . "440_xref")(cons 410 (getvar "CTAB")))))
     (setvar 'QAFLAGS 5)
     (setq i '-1)
     (repeat (sslength ss)
       (command "_.explode" (ssname ss (setq i (1+ i))) "")
VLA-explode method does not explode block with different scales in x, y, z
Temporarily changing the setting of QAFLAGS should allow a SelectionSet to be exploded without having to set through the set, does it not?
Thanks for the catch with vla-explode :)
(defun c:440 ()
Are you trying to explode xrefs? -David
Small addition
     (setvar 'QAFLAGS 5)
     (setq i '-1)
If you are stepping through the selection set and exploding each entity individually, you don't need to worry with QAFlags.
Thank alanjt that drew my attention. Added this technique to his piggy bank. I will add that to the command _explode there is a system variable EXPLMODE
