kalamees Posted October 11, 2010 Posted October 11, 2010 Hello, i need to count the lenght of all selected lines but my script keeps giving me this error: lentityp nil. Can anyone help? (defun c:joontepikkus() (setq SS2 (ssget '((0 . "LINE")))) (if SS2 (progn (setq enttext (entget text)) (setq objekt (cdr (assoc 0 enttext))) (if (= objekt "LINE") (progn (setq kogupikkus 0) (setq ss1len (sslength SS2)) (setq a 0) (setq i 0) (repeat ss1len (setq element (ssname SS2 i)) (setq aa (+ a aa)) (setq algkoords (assoc 10 enttext)) (setq algkoords (cdr algkoords)) (setq x (car algkoords)) (setq y (cadr algkoords)) (setq z (caddr algkoords)) (setq loppkoords (assoc 11 enttext)) (setq loppkoords (cdr loppkoords)) (setq x1 (car loppkoords)) (setq y1 (cadr loppkoords)) (setq z1 (caddr loppkoords)) (setq a2 (+ (+ (* (- x x1) (- x x1)) (* (- y y1) (- y y1))) (* (- z z1) (- z z1)))) (setq a (sqrt a2)) (setq kogupikkus (+ a kogupikkus)) (setq i (+ i 1)) ) (setq lause (strcat "Joonte kogupikkus on : " (rtos kogupikkus 2 3))) ) (alert lause) )))) Quote
pBe Posted October 11, 2010 Posted October 11, 2010 try this... i got this from off this forum but cant remember who though apologies (defun C:TLEN (/ ss tl n ent itm obj l) (setq ss (ssget) tl 0 n (1- (sslength ss))) (while (>= n 0) (setq ent (entget (setq itm (ssname ss n))) obj (cdr (assoc 0 ent)) l (cond ((= obj "LINE") (distance (cdr (assoc 10 ent))(cdr (assoc 11 ent)))) ((= obj "ARC") (* (cdr (assoc 40 ent)) (if (minusp (setq l (- (cdr (assoc 51 ent)) (cdr (assoc 50 ent))))) (+ pi pi l) l))) ((or (= obj "CIRCLE")(= obj "SPLINE")(= obj "POLYLINE") (= obj "LWPOLYLINE")(= obj "ELLIPSE")) (command "_.area" "_o" itm) (getvar "perimeter")) (T 0)) tl (+ tl l) n (1- n))) (alert (strcat "Total length of selected objects is " (rtos tl))) (princ) ) Quote
The Buzzard Posted October 11, 2010 Posted October 11, 2010 Try here:http://www.cadtutor.net/forum/showthread.php?42734-Line-Length-Calculator Quote
Lee Mac Posted October 11, 2010 Posted October 11, 2010 Something like this perhaps: (defun c:tLen nil ;; © Lee Mac 2010 ( (lambda ( SelSet Total i / entity ) (if SelSet (princ (strcat "\nTotal Length: " (rtos (while (setq entity (ssname SelSet (setq i (1+ i)))) (setq Total (+ (vlax-curve-getDistAtParam entity (vlax-curve-getEndParam entity) ) Total ) ) ) ) ) ) ) ) (ssget (list (cons 0 "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE") (cons -4 "<NOT") (cons -4 "<AND") (cons 0 "POLYLINE") (cons -4 "<OR") (cons -4 "&=") (cons 70 16) (cons -4 "&=") (cons 70 64) (cons -4 "OR>") (cons -4 "AND>") (cons -4 "NOT>") ) ) 0 -1 ) (princ) ) Quote
