OldMikeNewMember Posted October 16, 2010 Posted October 16, 2010 I saw somewhere that you can make dimensioning of a 2D object very quick by using "QuickDim" command whereby you wipe over the edges/face of a shape with a selection box (from bottom LH corner to top RH) and the dimensions magically appear. Is this something I saw for the full AutoCad version or is it in LT 2010 as well? Can someone advise how to use it? Ta Quote
ReMark Posted October 16, 2010 Posted October 16, 2010 Quick Dimensioning is available in both programs. How to use it? Have you taken a look in your Help file yet? QDIM - How to use it... http://books.google.com/books?id=trowcj1wZ44C&pg=PA304&lpg=PA304&dq=%22AutoCAD%22%2B%22Quick+Dimension%22&source=bl&ots=550tLKOlXs&sig=Q_EcgU9jSVwefOMcwi0_a46M9RQ&hl=en&ei=zoS5TLXUNMSAlAeErfnhDQ&sa=X&oi=book_result&ct=result&resnum=6&ved=0CCMQ6AEwBQ#v=onepage&q=%22AutoCAD%22%2B%22Quick%20Dimension%22&f=false Quote
OldMikeNewMember Posted October 16, 2010 Author Posted October 16, 2010 Quick Dimensioning is available in both programs. How to use it? Have you taken a look in your Help file yet? QDIM - How to use it... http://books.google.com/books?id=trowcj1wZ44C&pg=PA304&lpg=PA304&dq=%22AutoCAD%22%2B%22Quick+Dimension%22&source=bl&ots=550tLKOlXs&sig=Q_EcgU9jSVwefOMcwi0_a46M9RQ&hl=en&ei=zoS5TLXUNMSAlAeErfnhDQ&sa=X&oi=book_result&ct=result&resnum=6&ved=0CCMQ6AEwBQ#v=onepage&q=%22AutoCAD%22%2B%22Quick%20Dimension%22&f=false Thanks for showing me that ReMark - Great help I think - problem is that I type in QDIM or QUICKDIMENSION and it comes back with "unknown", even in help pages. I have AutoCad LT 2010 and I'm surprised I cannot find it in there. Am I doing things right? Quote
