the midget Posted October 18, 2010 Posted October 18, 2010 Hey kan iemand mij helpen ivm een crash van autocad in 3D modeling telkens als ik naar 3D modeling ga en mijn tekeningen open en daarin begin te werken, zoomen orbit enzo... dan begint mijn scherm te flikkeren gevolgd door deze error beeldschermstuurprogramma reageert niet meer en is hersteld beeldschermstuurprogramma AMD Driver reageert niet meer en is hersteld uiteraard zijn alle drivers up to date mijn pc heeft de volgende specificaties: Dell XPS 16 intel core i7 820 QM ATI Mobility Radeon HD 4670 is hier een oplossing voor? want mijn pc moet dit zonder problemen kunnen draaien . groeten Wim Quote
the midget Posted October 18, 2010 Author Posted October 18, 2010 now in English. Can anybody help me with my problem? I repetetly have a crash in autocad 2010 3D modeling. When I work on my drawings with orbit and zoom ... just the regular stuff, There appears an error: display driver does not respond and is restored display driver AMD Driver does not respond and is restored all the drivers that I need are installed ... and I have searched on the internet but I didn't find a solution.. hope you people can help me greetings Wim Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 Is AutoCAD 2010 current with all updates? Do you have hardware acceleration enabled or disabled? Quote
the midget Posted October 18, 2010 Author Posted October 18, 2010 How can I check that? I diddn't update autocad 2010 and I'm sorry but I don't know what you mean with ' hardware acceleration enabled or disabled " ... and I don't know where I should do those things. Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 A newbie to this forum and to AutoCAD too it appears. Updates are available from the AutoDesk website. Hardware acceleration can be checked by using the 3DCONFIG command and then clicking on the Manual Tune button. Quote
the midget Posted October 18, 2010 Author Posted October 18, 2010 c enable hardware acceleration is clicked. but it was already this way ... I checked for updates and there are a few... I just downloaded a couple I thought that would be necessary. I just tried and it got worse... fatal error and it closed automaticly... Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 A few updates? All you needed was one, Update 2 since updates are cummalative. Did you download the correct version? There is a version for 32-bit systems and another for 64-bit systems. What is your system (32-bit or 64-bit) and what update did you download? Don't you normally create a Restore Point before loading any new software or updates? Quote
the midget Posted October 18, 2010 Author Posted October 18, 2010 yes yes, I made a restore point ... and now I just updated '2' and my system is 64-bit and I downloaded the right one.. just tried again, but it diddn't help... it's still the same error from the beginning. Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 Let's back up. If you open a 2D drawing do you have any problems? If you open a 3D drawing but do NOT use 3Dorbit do you have any problems? What visual style do you work in normally when editing a 3D drawing? And you are sure it is not a driver problem? Is this a laptop by any chance? How much physical RAM is installed? Quote
the midget Posted October 18, 2010 Author Posted October 18, 2010 I don't have a problem in 2D I can open the drawings but when I start working with them, not only with orbit, there appears an error. I work in 2D wireframe, realistc or conceptual. it depends If it is a driver problem, I don't know what driver I need. but my drivers are normally up to date. because in the error appears: AMD Driver. so I went to google searched it and downloaded that update... but there diddn't changed anything my ati mobility radeon hd4670 is up to date. so i don't know what I should do, but my pc is strong enough to run autocad, I'm sure. the error just won't go away Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 It sounds like a bad driver to me. You should go only to the manufacturer's website (AMD / ATI) and download the driver from there. Is this a laptop? Yes/No? How much RAM is installed? 1GB, 2GB, I have no clue, other? What OS are you running and what version of the OS is it? Example: Windows 7 - Ultimate. Quote
the midget Posted October 18, 2010 Author Posted October 18, 2010 the downloads I get is from that website. it's a laptop indeed 4 GB ram and its windows 7 Home Premium but it's a new laptop it's 6 mounth's old, so I'm a little bit angry because it won't work ... and that's the only program I really need for school. is there a possibility, that it would go away when I reinstalled it... or got another version let's say a try out or something ... Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 Do NOT reinstall AutoCAD at this time. If you feel it is an AutoCAD related problem then try the REPAIR option first. An uninstall/reinstall should be an option of last choice (i.e. - desperation). Quote
the midget Posted October 18, 2010 Author Posted October 18, 2010 I can't see a repair option... and already thank you for your effort I'm just trying to make it work, and sorry I don't know that much about pc's =) Quote
Cad64 Posted October 18, 2010 Posted October 18, 2010 I work in 2D wireframe, realistc or conceptual. it depends I cannot stress this enough. DO NOT work in conceptual mode. Even on a high end system, conceptual style can bring your computer to its knees. You should only use conceptual or hidden for viewing purposes. Then switch back to wireframe or realistic for working. Please answer ReMark's previous questions. Is this a laptop and how much RAM do you have installed? Quote
the midget Posted October 18, 2010 Author Posted October 18, 2010 I already answered,, it's a laptop 4GB ram windows 7 home premium intel i7 820QM ati mobility redeon HD4670 1GB ok, I won't work in conceptual ... thanks Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 (edited) The Repair option can be found in Windows Add/Remove Programs. This link is for an article by AutoDesk regarding the Repair option and how to do a clean uninstall/reinstall of AutoCAD should it be necessary. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617 Edited October 18, 2010 by ReMark Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 I found a website where a couple of people were complaining of a problem similar to yours with their ATI Radeon graphics chip. Check out what they had to say. Pay particular attention to post #6. http://www.sevenforums.com/graphic-cards/15628-driver-issue-windows-7-ati-radeon-mobility-4670-a.html Quote
the midget Posted October 19, 2010 Author Posted October 19, 2010 The repair did not work ... and the problem with the ATI Radeon Graphics are on Acer laptops/ pc's ... and mine is from Dell... so I don't think it will solve my problmes Quote
ReMark Posted October 19, 2010 Posted October 19, 2010 The problem is the same. It doesn't matter that the laptops were made by different companies. All of you were getting the exact same error message. Have a cup of coffee and think on it. Yes, I did not think Repair would work. I threw that out there to keep you away from doing an uninstall/reinstall. The problem is not with AutoCAD it's with the driver. I don't expect you to believe me so this is where I bow out. Good luck in solving your problem. When you discover the real answer come back and share the solution with us. See ya. Bye. Quote
