hi friends,
This Stan-Elev lisp help you to place or check Station and Elevation of a profile
Steps:-
1. Load stn-elev lisp file
2. Set datum origin using command “ DAT ”
a. Enter station datum
b. Enter Elevation datum
c. Pick datum origin
3. Place station and elevation text by using command “ STN ”
a. Enter Vertical Scale factor
b. Pick Station Elevation point
c. Pick Text Location
4. Reset the datum origin to world by using command “ UW “
(always set UCS origin to World before closing the file)
Specifications:
New layer = prf_eltext
New dimension style = Dim Arrow Ann (this annotative dimension style will help you to change the text size by changing Annotative scale value)
Background mask Applied to the text
Thank you for my cadtutor friends to help me to create this Lisp
Stn-Elev.lsp
This is interesting and somewhat useful, I assume its metric notation. I'll see if I can convert to imperial and have the stations report as X+xx.xx (feet)
nice code...
Steve
;; Title : Station & Elevation
;; Purpose : To get Stn & pgl
;; Written : Bijoy.v.m
;; Date : Oct 2010
;; System requirement : Autocad 2007
;; Command : Dat, Stn & uw
;;----------------------------------------Sub Function to Add sep (+)------------------------------------
(defun annotate (/ text1 dec sep)
(setq sep "+")
(setq dec 3) ;;supress 0 if 3 digit eg 12.555 to 12.555
;; (if (= (substr text (strlen text) 1) "0") (setq dec 2)) ;;supress 0 if 2 digit eg 12.550 to 12.55
;; (if (= (substr text (1- (strlen text)) 2) "00") (setq dec 1)) ;;supress 0 if 1 digit eg 12.500 to 12.5
(if (= (substr text (- (strlen text) 2) 3) "000") (setq dec 0)) ;;supress 0 if 0 digit eg 12.000 to 12
(setq text1 (atof text))
(if (not (= (substr text 1 1) "-"))
(setq txt (strcat (rtos (fix (/ text1 1000)) 2 0) sep (substr (rtos (+ 1000 (rem text1 1000)) 2 dec) 2))) ;new code
(setq txt text)
) ;if
) ;defun
;;--------------------------------------Sub Function to Create Styles------------------------------------
(defun Styles()
;create text Style
(if (not (tblsearch "style" "Gen-Text")) (command "-style" "Gen-Text" "Arial.ttf" "A""yes" "No" 3.0 "1" 0 "n" "n"))
;create dimension style
(if (not (tblsearch "DImstyle" "Dim Arrow Ann"))
(command "dim" "style" "Gen-Text"
"DIMADEC" 0
"DIMALT" 0
"DIMALTD" 2
"DIMALTF" 1.000
"DIMALTRND" 0.0000
"DIMALTTD" 2
"DIMALTTZ" 0
"DIMALTU" 2
"DIMALTZ" 0
"DIMASZ" 3
"DIMATFIT" 3
"DIMAUNIT" 0
"DIMAZIN" 0
"DIMBLK" ""
"DIMBLK1" ""
"DIMBLK2" ""
"DIMLDRBLK" ""
"DIMCEN" 0
"DIMCLRD" 7
"DIMCLRE" 7
"DIMCLRT" 7
"DIMDEC" 0
"DIMDLE" 0.0000
"DIMDLI" 1.0000
"DIMEXE" 1.5000
"DIMEXO" 1.5000
"DIMFRAC" 0
"DIMGAP" 1.0000
"DIMJUST" 0
"DIMLFAC" 1000.0000
"DIMLIM" 0
"DIMLUNIT" 2
"DIMLWD" 0
"DIMLWE" 0
"DIMRND" 0.0000
"DIMSAH" 0
"DIMSCALE" 1.0000
"DIMSD1" 0
"DIMSD2" 0
"DIMSE1" 0
"DIMSE2" 0
"DIMSOXD" 0
"DIMTAD" 1
"DIMTDEC" 0
"DIMTIH" 0
"DIMTIX" 0
"DIMTM" 0.0000
"DIMTMOVE" 0
"DIMTOFL" 0
"DIMTOH" 0
"DIMTSZ" 0.0000
"DIMTVP" 0.0000
"DIMTXSTY" "Gen-Text"
"DIMTXT" 3.000
"DIMZIN" 0
"DIMFIT" 5 /e)
(command "dimstyle" "An" "y" "Dim Arrow Ann" "S" "")
) ;progn
) ;if
) ;defun
;;-------------------------------------------* error *----------------------------------------------------
(defun trap1 (errmsg)
(setq *error* temperr)
(setvar "clayer" clay)
(prompt "\nEnter Command UW to make UCS origin World © Bijoy.v.m AECOM Dubai")
) ;defun
;;-------------------------------------------Set Datum--------------------------------------------------
(defun C:dat (/ num op sta pga stb pgb)
(command "cmdecho"0)
(command "ucs" "w")
;;; input station
(if (not nf-ns) (setq nf-ns 0.000)) ; default number
(setq NUM (getreal (strcat "\nEnter Station datum : ")))
(if (not num) (setq num nf-ns) (setq nf-ns num))
;;; input pgl
(if (not sf-ss) (setq sf-ss 0.000)) ; default number
(setq SUM (getreal (strcat "\nEnter datum Elevation : ")))
(if (not sum) (setq sum sf-ss) (setq sf-ss sum))
;;; set orign point
(setq op (getpoint "\nPick datum orgin point: "))
(setq sta (car op))
(setq pga (cadr op))
(setq stb (- sta num))
(setq pgb (- pga sum))
(command "ucs" "m" (list stb pgb 0))
(prompt "\nOrigin moved to new loaction - Enter Command STN to place Text")
) ;defun
;;-------------------------------------------Place Text--------------------------------------------------
(defun C:stn ()
(if (not sum) (alert "\n * Set DATUM Point *\n * Command - DAT *")(stn1))
) ;defun
(defun stn1 (/ pnt1 p1x p1y stdy dy ptxt e TextObj vlText)
(setq clay (getvar "clayer"))
(setq temperr *error*)
(setq *error* trap1)
(if (not (tblsearch "layer" "prf_eltext")) (command "-LAYER" "N" "prf_eltext" "C" "7" "prf_eltext" "LT" "Continuous" "prf_eltext""LW" "0.15" "prf_eltext" ""))
(Styles)
(command "CLAYER" "prf_eltext")
(command "-DIMSTYLE" "r" "Dim Arrow Ann")
;;; input Horizontal scale
(if (not hs) (setq hs 1)) ; default number
(setq hsm (getreal (strcat "\nEnter Vertical Scale factor : ")))
(if (not hsm) (setq hsm hs) (setq hs hsm))
(if (not sum) (prompt "\nSet Datum Point"))
(setq ptlist nil) ; for while command
(while
(setq PNT1 (getpoint "\nPick Stn.Elev. point: "))
(setq P1X (car pnt1)) ;x coord
(setq P1Y (cadr pnt1)) ;y coord
(setq STDY (rtos (+ (/ (- p1y sum)hsm) sum) 2 3)) ;; vertical scale calculation
(setq text (rtos P1X 2 3))
(annotate)
(setq PTXT (getpoint "\nPick text location: "))
(SETVAR 'DIMTAD 0) ; Justification centered
(SETVAR 'DIMLDRBLK "_ORIGIN") ;; leader arrow
(command "leader" PNT1 PTXT "" (strcat "Sta. " txt) (strcat "Elev. " STDY) "")
(setq TextObj (entlast))
(vl-load-com)
(setq vlText (vlax-ename->vla-object TextObj))
(vlax-put-property vlText 'backgroundfill :vlax-true) ; background mask
(SETVAR 'DIMTAD 1 ) ; Justification above
(setvar "DIMLDRBLK" ".") ;;leader arrow
(setq by (strcat (Chr 66)(Chr 73)(Chr 74)(Chr 79)(Chr 89)(Chr 183)(Chr 86)(Chr 183)(Chr 77)))
(setq ptlist (append ptlist (list pt))) ; to stop while command
) ;progn
) ;while
) ; defun
;;----------------------------------------Back to UCS World--------------------------------------------
(defun C:uw ()
(command "ucs" "w")
(prompt "\nUCS Origin is set to World")
) ; defun
(prompt "\nLisp Commands: DAT(to set Datum point),STN(to place text),UW(reset Ucs to World)")
;;----------------------------------------------End-----------------------------------------------------
Edited by bijoyvm
bijoyvm...
What is different about results using post #4 vs. post #1 ??
Steve
added reset Current layer variable and it is easy to copy paste for unregisterd visitors...
Well, not so easy. You can see the problem on your last line where you have a colon : followed by a capital D. Which gives :D. Not to mention all your formatting and indentation disappears.
You need to enclose your code inside code tags. Just edit your post and place [ CODE ] before your lisp and [/ CODE ] thereafter - without the spaces in between the [ and ] though (I added those so it displays properly here).
Or if you edit the post, click the Go Advanced button, then select your lisp and click on the hash (#) button. This places the code tags for you. It's also available with the quick post of a new message - but not with the quick edit though :?.
  • 6 years later...
I will appreciate if you can send me the above title (latest station- elevation lisp and the instructions to follow. Thanks
Pls, can somebody help me with grid line lisp.
Thanks
