Hello GUYS. :)
How can I search for informations that are related to a layer in Layer List ?
Example .......
(setq txt (getstring "\n Enter Descriptions to look for it :" T ))
    (tblsearch "LAYER" ............................
Hope to hear from you all very soon.
My Kind emotions
...are you looking for wcmatch
Perhaps this will yield the result(s) you want:
(if (and (setq lay (getstring T "\n Enter Layer Name: "))
        (setq layList (tblsearch "LAYER" lay)))
 (setq result ([color=blue]cdr[/color] ([color=blue]assoc[/color] [i][color=red]<Index>[/color][/i] layList))))
Thank you so much
You have changed my sentence of the first getstring function, although it's asking about a descriptions of any layer that might be included in a Layer.
Take a look please once again ...
(setq txt (getstring "\n Enter [b][color="red"]Descriptions[/color][/b] to look for it :" T ))
Thanks a lot, hope you have the answer for it.
I do not understand what you are trying to do... you want to enter part of a layer description, then search for what layer it belongs to? :?
Thamks Renderman for your kind interests.
I want to search for a Layer or Layers according to the descriptions that they related to.
So I would give the Descriptions details and codes would indicate to a specific layer.
Best regards
If you already know the layer description, then you already know what layer it is, no?
This could just come down to an issue of internal/external layer naming conventions.
I want to look for a Layer because I do not know which layer belong to a specific description . ( I have so many layers including Descriptions).
Thanks
I'm sure someone else has a brilliant solution, but for now, perhaps this will help:
(defun c:FOO  (/ txt desc hits)
 (vl-load-com)
 (if (setq txt (strcase (getstring "\n Enter Descriptions to look for it :")))
     (vlax-for lay  (vla-get-layers
                      (vla-get-activedocument
                        (vlax-get-acad-object)))
       (if (vl-string-search
             txt
             (strcase (setq desc (vla-get-description lay))))
         (cond
           (hits
            (setq hits (append hits
                               (cons (vla-get-name lay) desc))))
           ((setq hits (list (cons (vla-get-name lay) desc)))))))
     (if hits
         (textpage)
         (terpri)
         (prompt "\n  >>  Listing Possible Results... ")
         (foreach item  hits
           (prompt (strcat "\n\t\t** Layer Name = \""
                           (car item)
                           "\"\t** Description = \""
                           (cdr item)
         (terpri))
       (prompt "\n  <!>  No Results Found  <!> "))))
 (princ))
Note - In order for me to search the layer description(s) I needed to change the txt variable to only accept a single word. Accepting multiple words makes thing more complicated than I am willing to put into this.
Hope this helps!
Hi
This was my attempt, though I think RenderMan's is more suitable
(defun filterLayersByDescription (<pattern> / layerCollection tempLIst)
 (setq layerCollection (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
 (vlax-for <layer> layerCollection
   (if
     (wcmatch
(vla-get-description <layer>)
<pattern>
     (setq tempLIst (append tempLIst (list (vla-get-name <layer>))))))
 tempLIst
;Layers that have no description
(filterLayersByDescription "")
;Return a layers that have a description
(filterLayersByDescription "~")
;Return a layers that begin with T
(filterLayersByDescription "T*")
Filters would be case sensitive but the routine could be modified to suit
That is very kind of you to say.
Many experienced developers prefer functions with argument dependencies. In this case I *assumed* that the user may find entering a simple command preferable.
The main difference between the two is the usage of vl-string-search vs. wcmatch. With wcmatch you need to add the wildcards, whereas vl-string-search does not.
Overall, good job Jammie. :)
 (vl-load-com)
             txt
         (cond
           (hits
     (if hits
         (textpage)
         (terpri)
         (foreach item  hits
                           (car item)
                           (cdr item)
         (terpri))
 (princ))
Hope this helps!
A very great work Mr. RENDERMAN. and a very kind of you to do all for me.
You are really great.
Thank you soooooooo much.
Hi
   (if
     (wcmatch
<pattern>
 tempLIst
Wonderful coolection of codes Jammie.
Greatly appreciated.
Thank you sooooooooooooo much
Ehh, I was bored :roll: ... you're welcome. :) lol
In Vanilla :D
(defun SearchLayerDescription ( pattern / def l n )
 ;; © Lee Mac 2010
 (reverse
   (while
     (setq def
       (tblnext "LAYER"
         (null def)
     (foreach entry
       (cdadr
         (assoc -3
           (entget
             (tblobjname "LAYER"
               (setq n
                 (cdr
                   (assoc 2 def)
             '("AcAecLayerStandard")
       (if
         (and (= 1000 (car entry))
           (wcmatch (cdr entry) pattern)
           (not (member n l))
         (setq l (cons n l))
     l
Thanks Lee. I would try it .
Thank you so much.
Thanks for that! Trying expand my knowledge of Visual Lisp so learned something new today
Regards
Jammie
Not a bother glad to help
Happy coding
Regards
Jammie
... Welcome to 'the pack'. :wolf:
Buzz's girlfriend...WOOF!
