EvilSi Posted September 17, 2008 Posted September 17, 2008 Hello there, I can't remember which variable it is I need in order for the following to work: I have a lisp for annotating co-ordinates. I insert a little block, then run the lisp which allows me to click on a point and have a little co-ordinate box appear. When I do this though, a dialogue box pops up to prompt me to enter values, rather than just filling the values in automatically. It's been years since I've had to change this setting, so I've forgotten. It's the setting that allows you to insert a block with attributes without it prompting you with a dialogue box. Thanks for your help! Quote
NBC Posted September 17, 2008 Posted September 17, 2008 the variable in question is called ATTDIA. In this instance it would require a setting of 0 (zero). Quote
EvilSi Posted September 17, 2008 Author Posted September 17, 2008 Thank you, that's excellent! This forum is priceless! Quote
