Spinxy Posted October 21, 2010 Posted October 21, 2010 Hi ya. After seeing another post on here i have used and added to some of the macro to come up with a way of making a tidy (rectang) rev cloud with rev triangle. the user inputs i have got it down to so far is 1.picking the extents of the rectang 2. picking the rectang to turn it into a cloud 3. placing the rev triangle. it also switches it to a revision layer then back to the current layer you was working in once finished. ^C^C(setq a(getvar "clayer"));-layer;M;Revision;;rectang;\\revcloud;a;10;10;;\;-Insert;"Rev_Tri.dwg";\1;1;0;-layer;S;!a;; now i would like to get rid of the second user input of having to select the triangle, can anybody help? Cheers Quote
BIGAL Posted October 21, 2010 Posted October 21, 2010 A couple of subtle changes for clarity ^C^C(setq a(getvar "clayer"));-layer;M;Revision;;rectang;\\revcloud;arc;10;10;;\;-Insert;"Rev_Tri.dwg";\1;1;0;(setvar "clayer" a) so you dont mix the a's up Did you mean rectang can use "last" to pick your rectang automatically revcloud;arc;10;10;ob;L; command line test revcloud arc 10 10 ob L Quote
Spinxy Posted October 21, 2010 Author Posted October 21, 2010 cheers for that, it's working pretty well. also understood about the a's. i've also added tilemode;0; to the start to ensure all clouds are drawn in paperspace. Quote
