chelsea1307 Posted October 21, 2010 Posted October 21, 2010 Opened a dwg that was worked on earlier today and looked fine. Now when in model space arrowheads that should be filled are not. When in paperspace through the viewports the arrowheads look fine. Not a huge problem, we can still print fine but were not used to seeing it that way and would like it to go back to normal. fillmode is set to 1, arrowheads are on leaders and in blocks, dont have any dimensions. Quote
JPlanera Posted October 21, 2010 Posted October 21, 2010 interesting... try an audit. post the dwg here to see if anyone else experiences the same issue... Quote
chelsea1307 Posted October 21, 2010 Author Posted October 21, 2010 Attached is the problem dwg, I had to delete and purge alot before it would be small enough to load, none of that affected the arrows. ARROWS.dwg Quote
BlackBox Posted October 21, 2010 Posted October 21, 2010 The problem is that in Modelspace, you are not in an orthographic view, you're in a 'near' Top view. To fix this, simply go to View > 3D Views > Top. Hope this helps! Quote
