Walk Out Basement/Grading
I'm working on a house that is made on a signifigant slope, I've established my levels and a basement, although I want it to be a walk out basement but the slope goes through the basement. How would I erase or trim the material inside the basement to make it a full walk out? Is it grading? Or is there someway to trim the site that is already in the basement.
I've tried attatching a file so you can visually see the problem, but it says its an invalid file. Its saved as a .RVT, should i save it as a different file or what? Any suggestions on either problem would be appreciated. Thank you.
Nevermind I found the issue, thank god for PADS!
