Basic Carlson Question (Units in Inches Instead of Feet)
I recently imported survey points from my Data Recorder into AutoCAD 2009 w/ Carlson. I plotted the points and all of the distances are in inches instead of feet.
I am hopeful that this is simply some small option or format issue but I cannot find it.
Additionally I already inversed these points in the data recorded and the distance is correct.
Thank you and sorry if there is a better forum for this.
Set your dimension style units format to either engineering or Architectural and they will display in feet-inches format. Set the precision as you wish.
If you set your style units format at decimal, scientific, or fractional they will display in inches only.
