Using AutoCad 2010.
I have used the following proceedure to load my VBA rounines.
I run the proceedure during startup and the keyin the command when I want to use may routine.
If I use the command twice the vba program loads twice.
Is there a way to test a vba program to see if it is allready load then load
the program only if it is not loaded.
The proceedure is listed is below:
(defun C:opn ()
(vl-vbaload "C:/PgCADvba/OpenDrawing.dvb")
(vl-vbarun "opn")
Thank you,
I don't know if there is a way of doing that one but how about load your VBA then run then unload it once you have finished.
(command "_vbaload" "myfile.dvb")
(command "filedia" 1)
(command "-vbarun" "mf")
(command "_vbaunload" "myfile.dvb")
Hope this helps
I am looking for a program that checks to see if a VBA program is allready loaded.
If loaded, don't load it again. If it is not loaded the program needs to load it.
Is there a way to do that?
Thank you,
This *may* be what you're after...
Command Macro:
^C^C^P(if (not c:[color=red][i]FOO[/i][/color]) (load "[color=red][i]<FilePath>[/i][/color]\\[color=red][i]FOO[/i][/color].lsp")) c:[color=red][i]FOO[/i][/color]
LISP Command:
(defun c:[color=red][i]FOO[/i][/color] (/ appName)
 (vl-load-com)
 (setq appName (strcat "[color=red][i]<FilePath>[/i][/color][color=#000000]\\[color=red][i]<FileName>[/i][/color].dvb" "![color=red][i]<MacroName>[/i][/color].lrb"))[/color]
 (vl-vbarun appName)
 (princ))
Now, to unload the VBA Macro...
Either include a sub-function call at the end of your macro, or use a command reactor (reference the :vlr-CommandEnded event in the Developer Documentation) to run:
(vla-unloaddvb [color=red][i]<ApplicationObject>[/i][/color])
Hope this helps!
Edit:
Be sure to use
 tags.
