How to start a lisp like DInfo Belong to LEE?
A question from a begginer:
How to add a data to mouse pointer such as LEE lisp DInfo?
You will need to master the grRead function to accomplish that - it tracks all user input from mouse & keyboard, hence in a loop one can continously monitor user input.
Is there an simple example?
Because I tried to study DInfo lisp but lost.
Its higher technique more than my little knowledge.
Have you read the help file on grRead? I can provide an example, but it would serve no purpose if you didn't know how grread functioned.
In fact I did but didnt understand the help file.
Clunky example I did.
You have to understand, grread is neat and fun, but mostly it's useless and requires too much work/aggravation for the tiny payoff.
Its a poor start
starting from a lisp from this thread
But have 2 errors
- when point to Vertical line
- when point to pline
(defun C:IntLine ()
 (prompt "\nMove Crosshairs To Inspect Objects.")
 (while (and
   (setq INPUT (grread T))
   (= (car INPUT) 5)
     (setq INPUT_COORD (cadr INPUT))
     (setq ENTITY_FOUND (ssget INPUT_COORD))
     (if ENTITY_FOUND
(Progn
  (setq ENTITY_LIST (entget (ssname ENTITY_FOUND 0)))
         (setq p1 (cdr (assoc 10 ENTITY_LIST)))
         (setq p2 (cdr (assoc 11 ENTITY_LIST)))
  (setq tan2 (/ (- (cadr p2) (cadr p1)) (- (car p2) (car p1))))
  (prompt (strcat "\rObject: " (rtos (abs (* tan2 100))2 2) "%                     "))
LWPolylines don't have 11 codes. If you are just wanting start and end, I'd suggest the vlax-curve-getStartPoint, vlax-curve-getEndPoint (and no, you don't have to convert to vla-objects). However, for what you're doing, I'd also filter the polylines to only have one segment (dxf code 90, I think); you don't want to make your calculation based on a polyline with 75 bends, when you are wanting the angles between the start and end points.
Oh yeah, you might also be interested in grtext; it will display your message at the bottom left of the AutoCAD window.
Quick example I suppose:
(defun TextDisplay ( text / e l gr vs )
 (if (setq e
       (entmakex
         (list
           (cons 0 "TEXT")
           (cons 10 (getvar 'VIEWCTR))
           (cons 40 (/ (getvar 'VIEWSIZE) 30.))
           (cons 1 text)
           (cons 62 3)
           (cons 72 0)
           (cons 73 3)
           (cons 11 (getvar 'VIEWCTR))
   (progn (setq l (entget e))
     (while (= 5 (car (setq gr (grread 't 13 0)))) (setq vs (getvar 'VIEWSIZE))
       (entupd
         (cdr
           (assoc -1
             (entmod
               (subst (cons 11 (trans (polar (cadr gr) (/ pi -4.) (/ vs 20.))  1 0)) (assoc 11 l)
                 (subst (cons 40 (/ vs 30.)) (assoc 40 l) l)
     (entdel e)
(defun c:test nil (TextDisplay "Lee Mac") (princ))
  • 1 month later...
DInfo return error for entity "POLYLINE" into XREF and INSERT...
