Alaskachick Posted October 28, 2010 Posted October 28, 2010 I am trying to write a macro for a new command located on a custom toolbar button to call up a lisp located in a folder on a network. I want the path to be relative so different users can all access the same file. I have added the search path to my "support file search path" folder under options. Here is the macro I have so far: ^C^C(if c:CE1117 nil (load (strcat /autodesk/utilites/lisp/1pp "CE1117")));CE1117 I don't know how much of the path to the network location I need to include. I just did the last three folders. Also, I have no idea how many /'s to add before the folder name. I have tried various quantities and nothing is working. This is what I get when I hit the button to call the lisp: Command: (if c:CE1117 nil (load (strcat /autodesk/utilites/lisp/1pp "CE1117"))); error: bad argument type: stringp nil Command: CE1117 Unknown command "CE1117". Press F1 for help. It is possible to do this right? Quote
Alaskachick Posted October 28, 2010 Author Posted October 28, 2010 Well, I think I figured it out. I had too much info in my macro. If the support path is added that leads to the folder on the network then this macro works great: ^C^C(if c:CE1117 nil (load (strcat "CE1117")));CE1117 Quote
