manchest Posted November 1, 2010 Posted November 1, 2010 Hi I have just changed from AutoCAD 2009 to AutoCAD 2010 The Draw and Modify sections of the Ribbon bar are not as wide as they are in 2009 also there are 3 rows of icons where 2009 only has 2 rows. The icons are also smaller and seem a bit tucked away in the corner. Is it possible to customize the size of each panel inside the ribbon bar and the size of the icons? Quote
manchest Posted November 1, 2010 Author Posted November 1, 2010 Ok I have sorted out how to change the panel size. if you go to customize you can add more tools to each line of the ribbon which extends the size of the panel, you can also delete row 3. I still can not see how I can increase the size of the icons slightly Quote
ReMark Posted November 1, 2010 Posted November 1, 2010 Aren't there really only two sizes icons can be displayed at: 16x16 or 32x32? Quote
