Guest cad2007 Posted November 2, 2010 Posted November 2, 2010 Forrotation to Zero Degree.dwgwhat ever entyties i am selecting its need to come to zero degree.please look the drawing.... Quote
Tharwat Posted November 2, 2010 Posted November 2, 2010 I couldn't get what you mean , although I opened your uploaded dwg. So all entities are in zero in Z coodinates . Quote
Guest cad2007 Posted November 2, 2010 Posted November 2, 2010 plz see that drawing bootom VBR-99,VBR-100...that entire setting after(What ever i am selection) its need to come to Zero degree.I am changed that slide settings(In drawing) angle changed like that arrow datas(PLease look side).... Quote
Guest cad2007 Posted November 2, 2010 Posted November 2, 2010 not for all...only my selection datas only need to consider.......plz see the drawing and side yellow box..... Quote
Guest cad2007 Posted November 3, 2010 Posted November 3, 2010 here i have attached clear reference dwg for zero degree rotation changeRotation_Reference.dwg..please try to see.... Quote
alanjt Posted November 3, 2010 Posted November 3, 2010 23 posts of nothing but gimmie gimmie gimmie. Quote
eldon Posted November 3, 2010 Posted November 3, 2010 The poster wants to automate everything, and judging by some of the routines copiously posted before, who can blame him. Where should the blame be cast :shock: Quote
Cad64 Posted November 3, 2010 Posted November 3, 2010 That's fine, but if he wants to automate everything, then he should learn how to write his own code instead of coming here and taking advantage. Quote
Guest cad2007 Posted November 3, 2010 Posted November 3, 2010 i am tried but i cannt do this code...so only i am asking......i am expect u r help in this time... Quote
Cad64 Posted November 3, 2010 Posted November 3, 2010 What have you tried? Post your code here. Quote
mdbdesign Posted November 3, 2010 Posted November 3, 2010 Will give you head start... ;Copyright by cad2007 ;This program will rotate selected objects to zero degree (Defun c:rt0 () [color="red"]insert your code here[/color] ) Quote
Tiger Posted November 4, 2010 Posted November 4, 2010 Again, if you have nothing constructive to add to a thread, don't post anything at all. Quote
ReMark Posted November 4, 2010 Posted November 4, 2010 Maybe this thread should be closed as well? I think everyone who has felt the need to vent has done so by now. Quote
VisDak Posted November 4, 2010 Posted November 4, 2010 Oh my, you have much requested in here Sorry but better you use the standard command on your Autocad its all in there you needed, you dont have to use that as code, (rotate or align is the solution) you have to consider first if you need a code on it before you post. Quote
BlackBox Posted November 4, 2010 Posted November 4, 2010 Again, if you have nothing constructive to add to a thread, don't post anything at all. Clearly some of my earlier attempts have been both unsuccessful, and removed, so perhaps this change in tact will be more fruitful. what ever entyties i am selecting its need to come to zero degree. (What ever i am selection) its need to come to Zero degree. Balaji, *IF* you apologize for trying to deceive others, in order to get free code, I will genuinely try to help you. (if not this thread, then another) ... The choice is yours. Quote
