JerryFiedler Posted November 3, 2010 Share Posted November 3, 2010 Greetings, I have buttons on a panel to make dimensions either with both leaders, one leader (first or second) and no leaders. The macro on a the "both leaders" button is: ^C^C(setvar "dimse1" 0)(setvar "dimse2" 0);_dimlinear The other buttons have the same macro but the values for the variables are either 1 or 0 as appropriate. When I first open AutoCAD the "both leaders" works fine and the others also work. I can switch back and forth between the single leaders and no leaders but when I go back to use the "both leaders" button the dimension repeats the previous setting. The only way to return to both leaders is by entering the system variables on the command line. What am I doing wrong? Any help will be greatly appreciated. Regards, Jerry Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted November 3, 2010 Share Posted November 3, 2010 Not sure if its what you are after, but I wrote this a while back... ;; Toggles the display of Dimension Extension Lines ;; Helpful when OSnapping near dimensions! (defun c:dtog ( / doc ss ) (vl-load-com) ;; © Lee Mac ~ 11.06.10 (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (if (ssget "_X" '((0 . "DIMENSION"))) (progn (vla-StartUndoMark doc) (vlax-for obj (setq ss (vla-get-ActiveSelectionSet doc)) (if (vl-every (function (lambda ( p ) (vlax-property-available-p obj p)) ) '(ExtLine1Suppress ExtLine2Suppress) ) (mapcar (function (lambda (x) (vlax-put obj x (~ (vlax-get obj x)))) ) '(ExtLine1Suppress ExtLine2Suppress) ) ) ) (vla-delete ss) (vla-EndUndoMark doc) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
