Hi,
I use Autocad in both English and German versions and have a little tip for people using Autocad in a language other than English.
If you come across a new (new to you that is) command in English and what to know what is the equivalent in your language type the command in using the _ symbol before the english command and after exiting the command use the up arrow to see the command history, the command if available in your language will be displayed in your language and not the english version u typed
