Helo guys!
Is something like this possible?
I was thining something like this. YOu draw a line/polyline and then somehow insert a filed that always shows its distance. When you stretch a line, field automaticly updates.
Any chance you could copy the line with its filed so you dont have to define everything allover again?
Could this maybe work with closed polylines to describe area?
Many thanx!
Yes.
Just make sure you copy the field with related object.
Can you help me out a bit and describe how to do all this ?
Thanx :-)
Draw line
mtext
select field for text
object
select line
length
OK
The polyline answer theres some lisp out there to do this pick polyline place text change polyline text changes search here for hect.lsp area.lsp ?
Thanx a bunch man!
One thing that pops to my head, any chance that you could add some values to the filed value. Egsample if the line lenght is 4,00m any chance that the fled could show result of 4,00m+1,25m?
So number 5,25m should be displayed.
Thanx!
