okliw Posted November 3, 2010 Share Posted November 3, 2010 hy there can anyone show me how to create a block wich i can use over and over again without saving it to al the blocks in the drawing ? it needs to be ajustible but not to be saved in al the blocks with the same name. the arc has to be always d=150 the rest of it has to be sizeable mondje.dwg Quote Link to comment Share on other sites More sharing options...
KRBeckman Posted November 3, 2010 Share Posted November 3, 2010 hy there can anyone show me how to create a block wich i can use over and over again without saving it to al the blocks in the drawing ? it needs to be ajustible but not to be saved in al the blocks with the same name. the arc has to be always d=150 the rest of it has to be sizeable You might want to save it as an older AutoCAD file type... for us working for companies that don't keep thier software updated. Quote Link to comment Share on other sites More sharing options...
okliw Posted November 3, 2010 Author Share Posted November 3, 2010 You might want to save it as an older AutoCAD file type... for us working for companies that don't keep thier software updated. ok its done cad 2004 mondje.dwg Quote Link to comment Share on other sites More sharing options...
KRBeckman Posted November 3, 2010 Share Posted November 3, 2010 ok its done cad 2004 Have you looked into Dynamic blocks? Quote Link to comment Share on other sites More sharing options...
pBe Posted November 4, 2010 Share Posted November 4, 2010 Have you looked into Dynamic blocks? He's right... Here's your block with stretch parameters try it... explore it... edit it.. use it.. its up to you mondje.dwg Quote Link to comment Share on other sites More sharing options...
okliw Posted November 5, 2010 Author Share Posted November 5, 2010 He's right... Here's your block with stretch parameters try it... explore it... edit it.. use it.. its up to you Thanks looks nice. How can i save this en load it into a drawing wen i need it without copy /paste Can i import it in some way width a comand at comandline ? Quote Link to comment Share on other sites More sharing options...
eyde Posted November 5, 2010 Share Posted November 5, 2010 There are several ways you can do it. 1. Insert command 2.Tool palettes 3.Design Center All of these ways are in Help for more info. Quote Link to comment Share on other sites More sharing options...
