What Effect support in CAD 2011 ??
superkames
Hi all . I'm a newbie here and needs your helps .:oops:
Here is my tune log :
Performance Tuner Results Log
Version: 18.1.0.7
Date of Last Tune: 7/4/2010
Machine Configuration
Processor Speed : 3.6 GHz
RAM : 4095 MB
3D Device
Name : ATI FirePro V8700 (FireGL)
Manufacturer : ATI
Chip set : FirePro V8700 (FireGL)
Memory : 2808 MB
Driver : 8.14.0001.6105
Your machine contains a 3D Device that is not certified.
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver: acaddm10.hdi
Current Effect Status:
Enhanced 3D Performance: Available and on
Smooth display: Available and off
Gooch shader: Available and using hardware
Per-pixel lighting: Available and on
Full-shadow display: Available and on
Texture compression: Available and off
Advanced material effects: Available and off
Available application drivers and effect support:
Software driver
Effect support:
Enhanced 3D Performance: Not applicable
Smooth display: Not applicable
Gooch shader: Software emulation only
Per-pixel lighting: Not applicable
Full-shadow display: Not applicable
Texture compression: Not applicable
Advanced material effects: Not applicable
Autodesk driver: Not Certified
Effect support:
atioglacad11_64.hdi
Effect support:
Smooth display: Not available
Advanced material effects: Not available
But in the performance tuning missing 2 effects : Smooth display & Advanced material effects . Anyone help me , thanks :):)
What happens if you disable it?
Enhanced 3D Performance: Not recommended and off
Gooch shader: Software emulation in use
Per-pixel lighting: Not available
Full-shadow display: Not available
Texture compression: Not available
No tweaking ,I just install performance driver. a picture of performance tuning.
//PS :What Effects are supported with your VGA card bro ?
