Sarah H Posted September 18, 2008 Posted September 18, 2008 I have a paper space with a wipeout layer over the plan and below a table. Yesterday I printed this off fine but today I need to print to a pdf and then print a paper copy, the pdf looks fine but when sent to a printer it prints a huge solid black rectangle where the wipeout layer is. It's definitely the wipeout and not the table, I tried another drawing with polygonal wipeouts. Anyone come across this? Quote
Dipali Posted September 18, 2008 Posted September 18, 2008 I don't use ewipeouts personally but this is very common problem. if you search with keyword 'wipeout' you will see many similar threads discussing it. Quote
Sarah H Posted September 18, 2008 Author Posted September 18, 2008 I've searched for this and haven't come up with an answer, sorry if it seems I'm being a lazy forum member, I honestly did search! Someone suggested teh printer driver was at fault, but this was never confirmed as the answer. I'll get my collegue [who was actually encountering the problem and blaming me!] to try that. Quote
skipsophrenic Posted September 18, 2008 Posted September 18, 2008 try this thread, There are a couple of links leading off it that might help, http://www.cadtutor.net/forum/showthread.php?t=18390 Quote
Sarah H Posted September 18, 2008 Author Posted September 18, 2008 So there's no solution?! How frustrating, a nice neat drawing on the screen and a terrible mess on the page! I just hope no one I've emailed pdfs to has this problem with the drawing, this could actually be really annoying. Do you know whether I should delete this post? Quote
sab423 Posted September 18, 2008 Posted September 18, 2008 What print driver are you using to create the pdf from AutoCAD? If your using a adobe print driver you will have this issue. You may want to try using the dwg to pdf.pc3 print driver supplied by autocad. This may take care of the problem. Quote
dbroada Posted September 18, 2008 Posted September 18, 2008 Do you know whether I should delete this post?Don't delete the post. Sometimes "there is no answer" is of benefit to somebody else. Quote
BOB'27T Posted September 18, 2008 Posted September 18, 2008 Do what sab423 said. I use this same setup, and have yet to have a problem with it. Quote
Dipali Posted September 19, 2008 Posted September 19, 2008 I've searched for this and haven't come up with an answer, sorry if it seems I'm being a lazy forum member, I honestly did search! Someone suggested teh printer driver was at fault, but this was never confirmed as the answer. I'll get my collegue [who was actually encountering the problem and blaming me!] to try that. I didn't mean to imply you were lazy, just thought I will give you heads up if you don't know about the search feature in this site. sorry if I have ofended you. Quote
Guest jonnyz Posted June 10, 2010 Posted June 10, 2010 As posted in other threads, the color should be 255. This worked for me. Color 7 may work also. Quote
Organic Posted June 12, 2010 Posted June 12, 2010 I remember I had this problem once also when I was learning how to use AutoCad (and used wipeouts as I didn't know any better then). It was going to be too much work and time to fix it (large set), so was only able to be printed from the CAD file, not the pdf. I certainly learnt my lesson after that. Quote
