what is Shade Selected Faces Toggle
hi,
when i add edit poly modifier to a spline and select a polygon face, i always get these multi colored lines scattered around.
i could turn these off by pressing f2, which i found to be shade selected faces toggle.
however these thing won't appear if i add edit poly to a geometry or add edit mesh to spline.
why is this?
so is it better to use an extruded spline or create geometry?
Can you post a screenshot?
I don't understand what you mean by "multi colored lines scattered around".
hi
here is a screenshot
spline circle
add edit poly, select polygon
:? That's pretty crazy. I've never seen anything like that before.
I just tried it on my machine and I don't have any lines appearing.
I'm wondering if it's a graphics display problem?
What are your computer specs and what version of Max are you using?
but it doesnt happen when i use spline, edit mesh or create 3d object, edit poly
ati hd 5850,
2010 64bit
Well, since I can't duplicate the problem, and I've never seen that happen before, I don't have any advice to give. You will just have to do some investigation on your own and see if you can determine what's causing it. :unsure:
I assume your computer specs are good?
Have you downloaded and installed the available hotfixes and service packs?
