Lisp file needing some help.
;;Moves an object in a parallel plane until it is perpendicular of another
;;it then rotates 1st object so that it lines up with it. Similar to
;;align command.
;;Written by Laison Albarado 11-09-2011
(defun c:rm (/ pt1 pt2 pt3 pt4 pt0 ang1 dst1)
(setq os (getvar "OSMODE"))
(setvar "OSMODE" (logior os 1 2 4 32 128 8192))
(setq pt1 (car (entsel "\nSelect 1st object: ")))
(setq dis1 (getdist "\nEnter Distance are select item: "))
(Setq pt3 (getpoint pt1 "\nSelect Reference point/object: "))
(command
"move" pt1 pt2
(setq ang1 (getangle pt1 pt3))
(setq pt4 (polar pt2 ang1 dst1))
(command
"rotate" pt1 pt3
(setvar "osmode" os)
  • Replies 37
  • The Buzzard
    19
  • Lee Mac
    8
  • laisonalbarado
    8
  • alanjt
    1
I notice you have posted this in every possible CAD forum, but have failed to answer any questions people are asking. Respond to some questions dude.
I guess the OP expects someone will post a fixed code without a reply from him.
Any day now, Any day............
;;align command.
(command
"move" pt1 pt2
(command
"rotate" pt1 pt3
Have you checked your same thread in Cad Forums that were given to you ?
You should reply to your thread to get your codes running the way you desire .
Tharwat
I have ran the code and this is came back:
RM
Select 1st object:
Enter Distance are select item: Specify second point:
error: bad argument type: point:
RM
Select 1st object:
Compare the two codes below, You made changes to the code between forums. Both are different.
You have a problem with the manner in which you are selecting the object. You also made variable changes that are inconsistant within the codes (Using variables in the command calls that are not set before in the program.) And your usage of the command calls with the variable are incorrect. (Another words you are using a variable where you should be using a sub-command.) Also what are you trying to do with osmode by using logior?
Posted at AUGI
;;Moves and object in a parallel plane of another until it is perpendicular
;;to it then rotates 1st object so that it lines up with it. Similar to
;;align command.
(setq pt1 (getpoint "\nSelect 1st object: "))
(setq pt2 (getpoint pt1 "\nEnter second point: "))
(setq pt1 (getdistance "\nEnter Distance are select item: "))
(command
"move" pt1 pt2
(command
"rotate" pt1 pt3
Posted on post one here.
;;align command.
(command
"move" pt1 pt2
(command
"rotate" pt1 pt3
Well "Buzzard" what you are saying it's messed up. LOL
Anyway, this my first try at writing code. I never it before. Yes I have different forums. I think the more the exposure the better chance of me getting the help that I need.
The line the has the "logior" in it. I had put out a question not that long ago, "When writing code and you get to where you are going to set you OSMODE setting can you set more than 1 setting in the same line"?
I want it basically to use to pick my source's item (the item that I want moved) either endpoint, midpoint, center or intersection depending on what I am moving.
I got this back:
(setvar "OSMODE" (logior os 1 2 4 32))
A buddy of mine gave me this part:
Logior is the best way to deal with the OSMODE setting, as it is a bit-coded value and you are effectively flipping the bits that aren't set, at the same time leaving those that are:
Explanation here:
http://www.cadtutor.net/forum/showthread.php?43975-Order-of-function&p=298061#post298061
Or similar, regarding boole:
http://www.cadtutor.net/forum/showpost.php?p=306339&postcount=9
I assume you also refer to this thread:
http://www.theswamp.org/index.php?topic=35639.0
I got this back:
OSMODE
Type: Integer
Saved in: Registry
Initial value: 4133
Sets running Object Snap modes using the following bitcodes:
0 NONe
1 ENDpoint
2 MIDpoint
4 CENter
8 NODe
16 QUAdrant
32 INTersection
64 INSertion
128 PERpendicular
256 TANgent
512 NEArest
1024 QUIck
2048 APParent Intersection
4096 EXTension
8192 PARallel
To specify more than one object snap, enter the sum of their values. For example, entering 3 specifies the Endpoint (bitcode 1) and Midpoint (bitcode 2) object snaps. Entering 16383 specifies all object snaps.
When object snaps are switched off using the Osnap button on the status bar, a bitcode of 16384 (0x4000) is returned, in addition to the normal value of OSMODE. With this additional value, developers can write applications for AutoCAD, and distinguish this mode from Object Snap modes that have been turned off from within the Drafting Settings dialog box. Setting this bit toggles running object snaps off. Setting OSMODE to a value with this bit off toggles running object snaps on.
I am not trying to be critical, It does seem randomly cut and pasted. Here is a good place to learn for beginners : http://www.afralisp.net/index.php
Explanation here:
Lee,
Thats the first time I seen that, Although I guess its pretty neat, But it looks like overkill for what is being accomplished in this case. You can still combine the right number of integer values to accomplish the same.
Edited by The Buzzard
Definitely not overkill - think about how you might perform the same task (that is, switching extra OSnaps on whilst leaving what is already on) without using bit manipulation...
Furthermore, you have a lot more control over the value when using these tools, (see my example of creating a toggle for instance) - and it makes sense to control a bit-coded value using functions designed to manipulate such values.
Lee
Lee
I saw those great examples and I will not argue with that, But in laison case in his code above, He is not using it the same way as in your toggle example.
Thanks -
But the way I interpret Laison's code is that he wants to enable those snaps (1 2 4 32 128 8192) in addition to the current OSnap setting, I'm intrigued as to a better way to approach this other than logior.
Aside - I'm not saying Laison's code is correct in its entirety, but I am curious of a better way to code the OSnap part, if my understanding of its purpose is correct.
EDIT: Quickly penned this function which, I hope, performs the same operation, but without the use of a bit-wise inclusive OR function (such as logior) - just for a comparison.
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] [color=black]_SnapSetting[/color] [b][color=RED]([/color][/b] n [b][color=BLUE]/[/color][/b] _GetBits [color=black]os [/color][b][color=RED])[/color][/b]
 [i][color=#990099];; This is not a practical example in[/color][/i]
 [i][color=#990099];; any way, as the easiest way to accomplish[/color][/i]
 [i][color=#990099];; this task would be to IOR the existing[/color][/i]
 [i][color=#990099];; snap value with that which is desired -[/color][/i]
 [i][color=#990099];; however, I am trying to demonstrate a possible[/color][/i]
 [i][color=#990099];; method to accomplish the same operation *without*[/color][/i]
 [i][color=#990099];; the use of bit-wise inclusive OR function.[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] _GetBits [b][color=RED]([/color][/b] x [b][color=RED])[/color][/b]
   [i][color=#990099];; This function returns a list of all the bits[/color][/i]
   [i][color=#990099];; that make up a bit coded value 'x'.[/color][/i]
   [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] _GetBits [b][color=RED]([/color][/b] x i [b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] [b][color=#009900]0[/color][/b] x[b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]=[/color][/b] i [b][color=RED]([/color][/b][b][color=BLUE]logand[/color][/b] x i[b][color=RED]))[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] i [b][color=RED]([/color][/b]_GetBits [b][color=RED]([/color][/b][b][color=BLUE]-[/color][/b] x i[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lsh[/color][/b] i [b][color=#009900]1[/color][/b][b][color=RED])))[/color][/b]
         [b][color=RED]([/color][/b]_GetBits x [b][color=RED]([/color][/b][b][color=BLUE]lsh[/color][/b] i [b][color=#009900]1[/color][/b][b][color=RED]))[/color][/b]
   [b][color=RED]([/color][/b]_GetBits x [b][color=#009900]1[/color][/b][b][color=RED])[/color][/b]
 [i][color=#990099];; Split n into its constituent bits and get the current[/color][/i]
 [i][color=#990099];; OSMODE value for comparison.[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] n [b][color=RED]([/color][/b]_GetBits n[b][color=RED])[/color][/b] [color=black]os [/color][b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=DARKRED]'[/color][/b]OSMODE[b][color=RED]))[/color][/b]
 [i][color=#990099];; Now we do the operation that a bit-wise inclusive[/color][/i]
 [i][color=#990099];; OR would do in one step: If the bits constituting[/color][/i]
 [i][color=#990099];; our value 'n' do not appear in the current OSMODE[/color][/i]
 [i][color=#990099];; value, then add them to it.[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] bit n
   [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]zerop[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]logand[/color][/b] bit [color=black]os[/color][b][color=RED]))[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] [color=black]os[/color] [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] [color=black]os [/color]bit[b][color=RED]))[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=DARKRED]'[/color][/b]OSMODE [color=black]os[/color][b][color=RED])[/color][/b]
Edited by Lee Mac
Thanks -
EDIT: Quickly penned this function which, I hope, performs the same operation, but without the use of a bit-wise inclusive OR function (such as logior).
[b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] [b][color=BLUE]os[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] [color=black]os [/color]bit[b][color=RED]))[/color][/b]
Ok, I see where your going with this now. It was his intent that you saw. When I looked up logior, The examples that autodesk provides are limited in explaination. So I did not see it quite the same way, But I get it now.
Thanks
Well, at least I hope I got it right... in any case, I hope this thread might be useful to others' understanding of the topic.
True, in my opinion, the best way to visualise it is in binary - so using those tables I provided in a previous link. The help on the boole function is slightly better in this respect. I'm glad I could help with your understanding :)
Looking back on it, a more common example of the use of such functions is in manipulating layers in Vanilla - i.e. freezing/thawing/locking/unlocking etc.
Think about how you might freeze a layer by changing (entmod) the layer table object (tblobjname), without changing whether it is locked/unlocked or perhaps frozen in viewports etc.
Here are a few examples:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] BitToggle [b][color=RED]([/color][/b] bit value flag [b][color=RED])[/color][/b]
 [i][color=#990099];; Function to include/exclude bit from[/color][/i]
 [i][color=#990099];; value, depending upon flag.[/color][/i]
 [i][color=#990099];; flag=1 include, flag=0 exclude.[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]boole[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] [b][color=#009900]4[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] flag [b][color=#009900]3[/color][/b][b][color=RED]))[/color][/b] bit value[b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] FreezeThawLayer [b][color=RED]([/color][/b] layer flag [b][color=BLUE]/[/color][/b] [color=black]elist [/color][b][color=RED])[/color][/b]
 [i][color=#990099];; layer: name of layer (string)[/color][/i]
 [i][color=#990099];; flag=1 freeze, flag=0 thaw[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] layer [b][color=RED]([/color][/b][b][color=BLUE]tblobjname[/color][/b] [b][color=#a52a2a]"LAYER"[/color][/b] layer[b][color=RED]))[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b] dxf [b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]entmod[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]70[/color][/b] [b][color=RED]([/color][/b]BitToggle [b][color=#009900]1[/color][/b] dxf flag[b][color=RED]))[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]70[/color][/b] [color=black]elist[/color][b][color=RED])[/color][/b] [color=black]elist[/color]
     [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]70[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] [color=black]elist [/color][b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] layer[b][color=RED]))))[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] LockUnlockLayer [b][color=RED]([/color][/b] layer flag [b][color=BLUE]/[/color][/b] [color=black]elist [/color][b][color=RED])[/color][/b]
 [i][color=#990099];; flag=1 lock, flag=0 unlock[/color][/i]
           [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]70[/color][/b] [b][color=RED]([/color][/b]BitToggle [b][color=#009900]4[/color][/b] dxf flag[b][color=RED]))[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]70[/color][/b] [color=black]elist[/color][b][color=RED])[/color][/b] [color=black]elist[/color]
I am looking at your post about the osmode setting and using logior. My goal was to use just these settings.
Apparently if I am correct I must turn off my osnaps than set the osmode setting. Also, when I set the osmode setting, if I am going to use more than 1 I should add them up.
Is this what I getting from the posts?
Judging from your original post, the code you are currently using is setting those OSMODE settings in addition to those already set.
To set just those settings, you could store the current setting, then overwrite it with the settings you want, i.e.:
(setq os (getvar 'OSMODE))
(setvar 'OSMODE (+ 1 2 4 32 128 8192))
Then restore the old setting at the end of the code (and in the error handler):
(setvar 'OSMODE os)
As an aside, (boole 5 os (+ 1 2 4 32 128 8192)) would give the same result.
I guess I was not off the mark afterall.
(setq os (getvar "OSMODE")) ;Save User Object Snaps
(setvar "OSMODE" Your new setting here) ; Add-on to your orginal object snap setting
(setvar "OSMODE" os) ;Restore your Saved User Object Snaps
In any case, I have enjoyed the deviation in this thread, and I hope my earlier posts aren't wasted.
