Hatch scale regen
I have a user that when they insert a hatch pattern they have to double click on the hatch and then select the OK button in order for the hatch to be the correct scale even though the scale is set correctly. I fixed this once before but now I am having a really bad case of CRS and can't recall what I had to change. They say with age comes wizdom. But, what they don't tell you is that with age also comes... now what was I talking about???:?
Yep, been there done that. This user had this problem once before and it was a simple setting. But I'll be damed if I can remember what it was. Auxiliary scale is set to "Dimscale" but it comes in at 1 until he double clicks to get into the hatch edit and then he selects the OK button and the hatch corrects itself.
