san Posted November 16, 2010 Posted November 16, 2010 Good afternoon all, Please help me read the lisp sentences. 1, (if (not xxx:filename) ......) Why is "xxx:" put there? What does this mean? 2, (command ".undo" "be") What does this mean? When should we put ".undo" in lisp? Thanks a lot san Quote
Lee Mac Posted November 16, 2010 Posted November 16, 2010 1) xxx:filename may just be a variable name - the xxx: doesn't mean anything in particular. 2) (command ".undo" "be") Starts an undo mark so that, when the undo mark is ended, all the operations performed between the markers can be undone in one undo command. Quote
san Posted November 17, 2010 Author Posted November 17, 2010 1) xxx:filename may just be a variable name - the xxx: doesn't mean anything in particular. 2) (command ".undo" "be") Starts an undo mark so that, when the undo mark is ended, all the operations performed between the markers can be undone in one undo command. Thank you Lee for your quick answer. I try to understand What does "be" mean in sentence 2) Thanks again san Quote
giskumar Posted November 17, 2010 Posted November 17, 2010 What does "be" mean in sentence 2) The "be" begins the undo command. Quote
