how can i import data from xml file to autocad custom properties?
ChirilaDan
I need some lisp or vba app so that i can fill in autocad custom properties values from an xml file. I am setting up a dwt file to use fields based on that custom properties. Thanks
I have no idea how to import values from an xml file but below is one way to add a custom property lisp-wise:
(vla-addcustominfo (vla-get-summaryinfo (vla-get-activedocument (vlax-get-acad-object))) PROP_NAME PROP_VALUE)
Of course you should include some type of check to see if the custom property already exists because the above code won't work if it does.
it's a good ideea! I have litle kwnolege in lisp or vba programing but i found a vba code witch is similar in a small way to what i need.The code below to specify a drawings custom properties.
Sub SetCustomDwgProps()
'Lines below set the standard properties
ThisDrawing.SummaryInfo.Author = ThisDrawing.GetVariable("LOGINNAME")
ThisDrawing.SummaryInfo.Comments = "Comments Created by VisibleVisual"
ThisDrawing.SummaryInfo.RevisionNumber = 1
ThisDrawing.SummaryInfo.Title = "VisibleVisual Example"
ThisDrawing.SummaryInfo.Subject = "Entering Properties"
ThisDrawing.SummaryInfo.Keywords = "Example, VBA, Code"
'The lines below create custom properties
Call setCustvalue("PLATFORM", ThisDrawing.GetVariable("PLATFORM"))
Call setCustvalue("COMPUTER", Environ("ComputerName"))
Call setCustvalue("SERIAL", ThisDrawing.GetVariable("_PKSER"))
Call setCustvalue("WEBSITE", "www.visiblevisual.com")
End Sub
'Set Custom Property Value
Sub setCustvalue(key, value)
Dim custvalue As String
Set oSumm = ThisDrawing.SummaryInfo
On Error Resume Next
oSumm.GetCustomByKey key, custvalue
On Error GoTo 0
If custvalue = "" Then
oSumm.AddCustomInfo key, value
Else
oSumm.SetCustomByKey key, value
End If
End Sub
how can i edit this code to suite my needs? sorry if my english is bad!
Try something like this
(vl-load-com)
(defun setvalue(info key value)
   (if (vl-catch-all-apply
'vla-removecustombykey
(list info key)
   (vla-addcustominfo info key value)
     (vl-catch-all-apply
(list info key)
(defun C:Cust(/ adoc dwgname info user)
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (setq info (vla-get-SummaryInfo adoc))
 (setq user (getvar "loginname"))
 (setq dwgname (getvar "dwgname"))
 (vl-catch-all-apply
     'vlax-put (list info 'Author user))
 (vl-catch-all-apply
     'vlax-put (list info 'Lastsavedby info user))
 (vl-catch-all-apply
     'vlax-put (list info 'Title dwgname))
 (vl-catch-all-apply
     'vlax-put (list info 'RevisionNumber "RX-100"));etc
;;customs
 (setvalue info "Key001" "Value001")
 (setvalue info "Key002" "Value002")
 (setvalue info"Key0033" "Value003");etc
 (vla-save adoc)
  • 3 weeks later...
Thanks for your help, but i need a code that could import those custom values "Value001", "Value002", "Value003" etc. from a cpxml file. I have multiple cpxml files, they all have the same tag's but diffrent values. All cpxml files were exported from a database. I created text fields on various titleblocks linked to custom dwg properties.
Post your xml file as attachment to see its structure
Here is just a framework only
try to complete it by yourself
(defun read_by_tags  (xml_doc tag / lst)
 (setq adr_elems (vlax-invoke-method
     xml_doc
     'getelementsbytagname
     tag))
 (setq leng (vlax-get-property adr_elems 'length))
 (setq cnt 0)
 (while (< cnt leng)
   (setq tmp (vlax-get-property
 (vlax-get-property
   (vlax-get-property adr_elems 'Item cnt)
   'firstchild)
 'text))
   (setq lst (cons tmp lst))
   (setq cnt (1+ cnt)))
 (cons tag (list (reverse lst)))
(defun C:demo(/ adr_elems info srt_elems ssp_elems xml_doc)
(vl-load-com)
(setq xml_doc (vla-getinterfaceobject  (vlax-get-acad-object)"msxml.domdocument"))
(while (not (eq :vlax-true(vlax-get-property xml_doc 'async)));wait for application accessibility
(vlax-invoke-method xml_doc 'load "C:/UsedFiles/sample.cpxml")
(setq info (mapcar  (function (lambda (x)(read_by_tags xml_doc x)))
        (list "ADDRESSID"
       "SIRSUP"
       "SIRUTA");etc. <-- add all of the desired tags here
(if xml_doc (vlax-release-object xml_doc ))
;; --> work with 'info' here, use 'foreach' or 'mapcar' for that
~'J'~
  • 2 months later...
thanks for the help, but if you could help me to the second part of code I would appreciate. I would save many hours of work on autocad with this code running.
Sorry don't understand what you mean about 'the second part of code'
please explain me this widely
  • 2 years later...
Hi!
fixo have done a great start to my whish read xml-files via Lisp. You get it "firstchild" in xml. what is if I have more childs:lol:
CutFillReport - Kopia.xml.txt
In this file I can read
(list "AeccCutFillReport"
"GeneratedTime"
"User"
"Drawing"
"VolumeSummary"
"Volume" ???
But the next is I want the volume results too. Sorry I have transformed your code to my wishes. Hopefully you understand that.
   (setq adr_elems (vlax-invoke-method xml_doc 'getelementsbytagname tag))
   (setq cnt 0)
   (while (< cnt leng)
                     (vlax-get-property
                     'firstchild
                 'text
       (setq cnt (1+ cnt))
(defun C:demo(/
;;;              adr_elems info srt_elems ssp_elems xml_doc
(vl-load-com)
(vlax-invoke-method xml_doc 'load "C:/temp/CutFillReport.xml")
              "GeneratedTime"
              "User"
              "Drawing"
              "VolumeSummary"
              "Volume" ???
(princ info)
;;;(if xml_doc (vlax-release-object xml_doc ))
