sharpooth Posted November 23, 2010 Posted November 23, 2010 Hello to all, I have a mymenu.cui file. After (menucmd "p14=+mymenu.POP01") i can not see the menu in menu bar. May be the problem is that is set to false. That is the reaseon to start write next code: (defun c:go () (vl-load-com) (setq menu-list nil) (setq acad (vlax-get-acad-object)) (setq mgs (vla-get-Menugroups acad)) (setq c (vla-get-count mgs)) (setq n 0) (repeat c (setq menu (vlax-invoke-method mgs "Item" n)) (setq menu-list (cons menu menu-list)) (setq n (+ 1 n)) ) (setq pops (vla-get-menus (nth 1 menu-list) )) (setq pop (vlax-invoke-method pops "Item" 0)) (setq status (vlax-get-property pop 'OnMenuBar)) (vlax-property-available-p pop 'OnMenuBar) (vlax-put-property pop 'OnMenuBar :vlax-true) ; <- Here I am receiving an error? ) I can not set OnMenuBar on :Vlax-true. Can any one help me? Thanks! Quote
