Raudel Solis
3d Rendering by Autodesk
Raudel Solis
final_Project_2_Counter_Top_4_Neon_-_Standard(3)_2010-12-05_12-57-35.jpg3d Rendering By autodesk in its beta stage but it works great
http://neon.labs.autodesk.com/
thats the autodesk labs Project and you just upload your dwg files to autodesk and render
all you need to do is export your dwg into etransmit files with the
etransmit command
and then upload the zip file
and choose the quality and then the resolution
autodesk's Servers/ Super computers will render everything precisely and in 1/4 1/8 1/16 the time it will take a core 2 duo and most core i7s
its awesome give it a try
you must have at least 1 named view and
1 light in order to render
so create a camera and a light if you dont have one
ive got a sample file
its simple but its rendered at 1920 * 1080
and it took a shorter time period than it would take my core i7 laptop
Share this post
Link to post
edwinprakoso
Do you use imperial units?
I tried my metric model, and it won't map my rendering materials correctly. Not sure if it still has the problem, I haven't tried it again.
Share this post
Link to post
Raudel Solis
i use my own template with units set to architectural feet and inches
with 0'0" precision
did you export your file into the etransmit format with the etransmit command?
Share this post
Link to post
edwinprakoso
Yes, it gives me the rendering result.
But the rendering material sizes are all wrong.
Share this post
Link to post
Raudel Solis
i dont know how to help, all my renderings turn out ok except some are a bit off on the colors
:huh:
Share this post
Link to post
ReMark
Now you know why it's called a "beta".
Share this post
Link to post
f700es
Interesting.....
Share this post
Link to post
