looking for a lisp that gives a mark to the option DWG HYPERLINK TO DWF in the hyperlink dialog (ctrl+k)
TKS,
Mike
i found something, but i have to drag it from explorer to Autocad, is there a other lisp that kan be loaded from appload.
found lisp:
(defun markHlinkDWF ()
(setq mysel (ssget "_X" '((-3 ("PE_URL")))))
(setq iMaxSel (sslength mysel))
(setq iCnt 0)
(while (< iCnt iMaxSel)
(setq my_entname (ssname mysel iCnt))
(setq my_ent (entget my_entname '("PE_URL")))
;; get the entity including Xdata for hlinks
(setq my_xdata1 (assoc -3 my_ent))
;; open up the XData
(setq my_xdata_URL (nth 1 my_xdata1))
(setq my_new_xdata_URL (subst '(1071 . 1) '(1071 . 0) my_xdata_URL))
;; enable flag for convert DWG to DWF
(setq my_new_xdata1 (subst my_new_xdata_URL my_xdata_URL my_xdata1))
;; update XData
(setq my_ent (subst my_new_xdata1 my_xdata1 my_ent))
(entmod my_ent)
;; set the entity
(setq iCnt (+ iCnt 1))
nil
(defun validate ()
(setq iCnt 0)
(setq iFailCnt 0)
(if (/= (member '(1071 . 0) my_xdata_url) nil)
(setq iFailCnt (+ iFailCnt 1))
(if (> iFailCnt 0)
(setq
my_str (strcat (itoa iFailCnt) " hyperlink(s) not updated.")
(princ my_str)
nil
