CAD Library Posted December 7, 2010 Posted December 7, 2010 Is it possible to transfer my cad drawings like floor plans to sketchup??? how? what software will I use? thanks! Quote
ReMark Posted December 7, 2010 Posted December 7, 2010 Yes it is. How? Via the Import command. Software: AutoCAD and Sketchup. What else would you be using? Quote
f700es Posted December 7, 2010 Posted December 7, 2010 Well if you are using Google SketchUp 8 (the free one) you will have some issues. Google, in it's great wisdom decided to remove the import .dwg/.dxf from the free version. I guess they needed the Pro's $500 price tag pretty bad. There are a few ways around this. I still use v7 as I did not see a real good reason to upgrade to v8 and I still need to import dwgs. Now you can have v7 and v8 installed side by side if you do like v8 and some of it's new features. Open v7 and import your dwg and then save and open in v8. You can also download and install the free dwg editor DoubleCAD XT. It is a AutoCAD LT clone and while you might not need another CAD program it can open dwgs and save them to skp (SketchUp files). You can also use it to open skp files and save them out as dwg files Good luck. Quote
CAD Library Posted December 14, 2010 Author Posted December 14, 2010 Import command on what? in autocad or in sketchup? Quote
ReMark Posted December 14, 2010 Posted December 14, 2010 Import command on what? in autocad or in sketchup? Sketchup. But as f700es stated you'd have to now be running the Pro version. You import into a program, therefore one would save as a dwg/dxf in AutoCAD and then import the file into Sketchup. Quote
ReMark Posted December 14, 2010 Posted December 14, 2010 Thanks Mark Just echoing your previous, excellent advice. I too was not aware that the import option was removed from the freebie version. Quote
f700es Posted December 14, 2010 Posted December 14, 2010 Pretty lame move IMHO for Google but that's their call. Quote
ReMark Posted December 14, 2010 Posted December 14, 2010 I think they call it "bait and switch". Quote
designerstuart Posted December 14, 2010 Posted December 14, 2010 there is a ruby that does it, but i think it only works in earlier versions (eg 7) search at sketchucation Quote
designerstuart Posted December 15, 2010 Posted December 15, 2010 here is the link to the plugin - but note it doesn't work on v.8 http://sketchup.google.com/intl/en/download/plugins.html#dwg Quote
Red333 Posted December 15, 2010 Posted December 15, 2010 Can you save to SketchUp in DoubleCad? I thought you can only open a skp and save it as a dwg, not the other way around. If it's possible, my life just got easier. Quote
f700es Posted December 15, 2010 Posted December 15, 2010 Not sure about that. I do know it can save to .DAE (collada) that SU has embraced. Quote
